Device paired successfully but no communication with zigbee2mqtt
I have a strange problem that I can’t seem to solve
BTW I’m using hassio 0.101.3 and zigbee2mqtt addon 1.7.1
I bought a gledopto downlight 9W (Model ID GL-D-004ZS) and paired successfully with zigbee2mqtt
zigbee2mqtt:info  2019-11-29T05:33:16: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"device_removed","message":"left_network","meta":{"friendly_name":"0x00124b001ef16597"}}'
zigbee2mqtt:info  2019-11-29T05:33:24: Device '0x00124b001ef16597' joined
zigbee2mqtt:info  2019-11-29T05:33:24: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"device_connected","message":{"friendly_name":"0x00124b001ef16597"}}'
zigbee2mqtt:info  2019-11-29T05:33:24: Starting interview of '0x00124b001ef16597'
zigbee2mqtt:info  2019-11-29T05:33:24: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","message":"interview_started","meta":{"friendly_name":"0x00124b001ef16597"}}'
zigbee2mqtt:info  2019-11-29T05:33:35: Successfully interviewed '0x00124b001ef16597', device has successfully been paired
zigbee2mqtt:info  2019-11-29T05:33:35: Device '0x00124b001ef16597' is supported, identified as: Gledopto LED RGB + CCT downlight 9W  (GL-D-004ZS)
zigbee2mqtt:info  2019-11-29T05:33:35: MQTT publish: topic 'zigbee2mqtt/bridge/log', payload '{"type":"pairing","message":"interview_successful","meta":{"friendly_name":"0x00124b001ef16597","model":"GL-D-004ZS","vendor":"Gledopto","description":"LED RGB + CCT downlight 9W ","supported":true}}'
I had to add it’s configuration in /zigbee2mqtt-1.7.1/node_modules/zigbee-herdsman-converters/devices.js to make it supported
    zigbeeModel: ['GL-D-004ZS'],
    model: 'GL-D-004ZS',
    vendor: 'Gledopto',
    description: 'LED RGB + CCT downlight 9W ',
    extend: gledopto.light,
    supports: 'on/off, brightness, color temperature, color',
The problem is that apart from the message that the gledopto downlight joined the network I get absolutely no communication between it and the zigbee gateway (CC2531)
I have the 6W version of this downlight (GL-D-003Z) and it communicates with no problem with zigbee2mqtt (actually I didn’t have to add an entry for it because it was already there in the default devices.js configuration)
This is the log of the (GL-D-003Z) :+1:
zigbee2mqtt:info  2019-11-29T05:36:43: MQTT publish: topic 'homeassistant/sensor/0x00124b001ea82c9a/linkquality/config', payload '{"unit_of_measurement":"-","value_template":"{{ value_json.linkquality }}","state_topic":"zigbee2mqtt/0x00124b001ea82c9a","json_attributes_topic":"zigbee2mqtt/0x00124b001ea82c9a","name":"0x00124b001ea82c9a_linkquality","unique_id":"0x00124b001ea82c9a_linkquality_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00124b001ea82c9a"],"name":"0x00124b001ea82c9a","sw_version":"Zigbee2mqtt 1.7.1","model":"LED RGB + CCT downlight  (GL-D-003Z)","manufacturer":"Gledopto"},"availability_topic":"zigbee2mqtt/bridge/state"}',
zigbee2mqtt:info  2019-11-29T05:36:43: MQTT publish: topic 'homeassistant/light/0x00124b001ea82c9a/light/config', payload '{"brightness":true,"color_temp":true,"xy":true,"schema":"json","command_topic":"zigbee2mqtt/0x00124b001ea82c9a/set","state_topic":"zigbee2mqtt/0x00124b001ea82c9a","name":"0x00124b001ea82c9a_light","unique_id":"0x00124b001ea82c9a_light_zigbee2mqtt","device":{"identifiers":["zigbee2mqtt_0x00124b001ea82c9a"],"name":"0x00124b001ea82c9a","sw_version":"Zigbee2mqtt 1.7.1","model":"LED RGB + CCT downlight  (GL-D-003Z)","manufacturer":"Gledopto"},"availability_topic":"zigbee2mqtt/bridge/state"}'
I checked the database.db file and I have the 2 entries, first one is the 6W downlight GL-D-003Z which works well, second one is the 9W downlight GL-D-004ZS that sends no message to zigbee2mqtt
{“id”:4,“type”:“Router”,“ieeeAddr”:“0x00124b001ea82c9a”,“nwkAddr”:46426,“manufId”:0,“manufName”:“GLEDOPTO”,“powerSource”:“Mains (single phase)”,“modelId”:“GL-D-003Z”,“epList”:[11,13],“endpoints”:{“11”:{“profId”:49246,“epId”:11,“devId”:528,“inClusterList”:[0,3,4,5,6,8,768],“outClusterList”:[],“clusters”:{“genBasic”:{“attributes”:{“modelId”:“GL-D-003Z”,“manufacturerName”:“GLEDOPTO”,“powerSource”:1,“zclVersion”:1,“appVersion”:1,“stackVersion”:2,“hwVersion”:1,“dateCode”:“20131206”,“swBuildId”:“2.0.0”}}},“binds”:[]},“13”:{“profId”:49246,“epId”:13,“devId”:528,“inClusterList”:[4096],“outClusterList”:[4096],“clusters”:{},“binds”:[]}},“appVersion”:1,“stackVersion”:2,“hwVersion”:1,“dateCode”:“20131206”,“swBuildId”:“2.0.0”,“zclVersion”:1,“interviewCompleted”:true,“meta”:{}}
{"id":10,"type":"Router","ieeeAddr":"0x00124b001ef16597","nwkAddr":31567,"manufId":0,"manufName":"GLEDOPTO","powerSource":"Mains (single phase)","modelId":"GL-D-004ZS","epList":[11,13],"endpoints":{"11":{"profId":49246,"epId":11,"devId":528,"inClusterList":[0,3,4,5,6,8,768],"outClusterList":[],"clusters":{"genBasic":{"attributes":{"modelId":"GL-D-004ZS","manufacturerName":"GLEDOPTO","powerSource":1,"zclVersion":1,"appVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20131206","swBuildId":"1.0.6"}}},"binds":[]},"13":{"profId":49246,"epId":13,"devId":528,"inClusterList":[4096],"outClusterList":[4096],"clusters":{},"binds":[]}},"appVersion":1,"stackVersion":2,"hwVersion":1,"dateCode":"20131206","swBuildId":"1.0.6","zclVersion":1,"interviewCompleted":true,"meta":{}}
OK, So I was able to control the device manually in hassio by issuing the following command in the mqtt developper tool :
{“state”:“ON”,“brightness”:100, “color”: {“x”: 0.123, “y”: 0.123}}
So basically hassio doesn’t recognise this device, is there a way to add in a configuration file so when automatic device discovery is enabled it’s recognized.
I have 50 devices like this one so it would be hard to add each manually.
Did you enable MQTT Discovery in home assistant?
I tried using discovery: true in the configuration file but the device doesn’t appear in hassio
This is not the same as “normal” discovery.
Do you have in your configuration.yaml
mqtt:
  discovery: true
Or
discovery: true
This is my full configuration.yaml file :
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
mqtt:
  broker: 192.168.31.226
  discovery: true
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
#   base_url: example.duckdns.org:8123
# Text to speech
tts:
  - platform: google_translate
group: !include groups.yaml
script: !include scripts.yaml
If I use the file above I can see GL-D-003Z models (Gledopto 6W downlight) in Hassio UI, but I can’t see GL-D-004ZS models (Gledopto 9W downlight PLUS)
If I edit the file like this
default_config:
mqtt:
  discovery: false
light:
  - platform: "mqtt"
    schema: "json"
    name: "Salle de Sport - Panel LED 01"
    state_topic: "zigbee2mqtt/Panel LED Plus"
    availability_topic: "zigbee2mqtt/bridge/state"
    brightness: true
    color_temp: true
    xy: true
    command_topic: "zigbee2mqtt/Panel LED Plus/set"
    rgb: true
# http:
# Text to speech
tts:
I can see GL-D-004ZS in Hassio UI. But it will be cumbersome to do it manually for 100 devices (Gledopto Downlights and Xiaomi switches)
Can you not use a combination of both, discovery enabled and add manually the devices which are not found by discovery?
Nope,
Seems when discovery is set to true all manual configuration is bypassed.
If anyone can confirm.
I have same problems with Gledopto devices(
Also the devices are turn_on on startup, and I don't know how to fix it(
