Device pictures of Zigbee2MQTT in HA?
The title tells everything. Is it possible to get the device pictures of Zigbee2MQTT, that are already existing in Zigbee2MQTT, in Home Assistant? Would be lovely to not need to add a device picture in Home Assistant manually for every device.
But I guess it’s not possible.
No actually, it doesn’t. What’s the question?
Didn’t you read the post?
Yes. If the device pictures are already shown in Home Assistant, why do you need to add a device picture in Home Assistant manually for every device? What are you trying to do?
it’s probably a grammar misunderstanding :wink:
Yep. It’s the comma. I meant the images are in Zigbee2MQTT. But not in Home Assistant. And I want them there too as entity pictures for example @Stiltjack
Ah, sorry abouit that. I was confused because the Z2M images do appear in my Home Assistant.
Are you using the Z2M add-on?
But your screenshot is of Z2M now, right?
Unfortunately, I cannot use any addons as I’m using Home Assistant in Docker and not supervised.
