Hello everyone.
I have Home Assistant Core with the default SQLite DB ed zigbee2mqtt on Docker.
A Zigbee MMQ temperature sensor is broken and I would like to replace it.
I would like to “hook” the history of the previous sensor to the new one, how do I do it?
Just rename the new entity to exactly the same name as the old entity.
I would delete the “temperature entity” and any other entity you want history for.
Then rename the new entities.
Finally delete the entire old device.
See here for more info:
Thank you, very kind, the steps are clearer now.
In my entity the delete button is disabled.
I can’t find anything about this in the post you suggested.
Do you know how I can delete it?
In that case, try to delete the entire device, just keep note of the entity names.
thanks! solved!
