Device seems to disconnect/sleep a few minutes after adding it to the Zigbee network. How can I fix this?
I have an automatic blinds motor (MOES) setup and connected to ZHA. If I issue open/close commands it works, but only for a few minutes. After a couple minutes, the motor fails to respond. Issuing an open/close command results in an error: “Failed to perform the action cover/open_cover. Failed to send request: device did not respond” I’ve reset (via the physical button on the motor) and reconnected the motor to the zigbee network three times. Always after only a few minutes it stops responding. Showing the Network Graph shows that it’s connected to the nearby repeater, but reading attributes and reconfiguring also fail. Any ideas on how to improve this situation?
