Home Assistant 2022.8.1
Supervisor 2022.07.0
Operating System 8.4
Frontend 20220802.0 - latest
I don’t understand, my device are reporting and working fine within Zigbee2MQTT but no anymore within home assistant Mosquitto broker.
How can I fix that?
PS I use both Zigbee2MQT and Z-WAVE JS (MQTT) but I don’t expect to be an issue?
Template variable warning: 'dict object' has no attribute 'stop_mobile_point2' when rendering '{{ value_json.stop_mobile_point2 }}'
17:36:02 – (WARNING) helpers/template.py - message first occurred at 17:31:04 and shows up 1656 times
Invalid color mode received
17:31:38 – (WARNING) MQTT - message first occurred at 17:31:38 and shows up 3 times
Platform netatmo not ready yet: None; Retrying in background in 30 seconds
17:30:58 – (WARNING) Sensor
Setup of media_player platform dlna_dmr is taking over 10 seconds.
17:30:54 – (WARNING) Media Player - message first occurred at 17:30:54 and shows up 2 times
Failed to to call /store -
17:30:36 – (ERROR) Home Assistant Supervisor - message first occurred at 17:30:36 and shows up 2 times
/store return code 500
The issue might be with Mosquito broker, here is the logs:
Full logs
1659716923: New connection from 172.30.32.2:45134 on port 1883.
1659716923: Client <unknown> closed its connection.
1659717017: Client 3UXGQY6gL6H4FYzqNXpHA1 closed its connection.
1659717043: New connection from 172.30.32.2:45136 on port 1883.
1659717043: Client <unknown> closed its connection.
1659717051: New connection from 172.30.32.1:48341 on port 1883.
1659717051: New client connected from 172.30.32.1:48341 as 1zbH65La7IEJzDrlTS0c6G (p2, c1, k60, u'homeassistant').
1659717163: New connection from 172.30.32.2:45138 on port 1883.
1659717163: Client <unknown> closed its connection.
1659717283: New connection from 172.30.32.2:45140 on port 1883.
1659717283: Client <unknown> closed its connection.
1659717403: New connection from 172.30.32.2:45142 on port 1883.
1659717403: Client <unknown> closed its connection.
1659717523: New connection from 172.30.32.2:45144 on port 1883.
1659717523: Client <unknown> closed its connection.
1659717643: New connection from 172.30.32.2:45146 on port 1883.
1659717643: Client <unknown> closed its connection.
1659717763: New connection from 172.30.32.2:45148 on port 1883.
1659717763: Client <unknown> closed its connection.
1659717883: New connection from 172.30.32.2:45150 on port 1883.
1659717883: Client <unknown> closed its connection.
1659718003: New connection from 172.30.32.2:45154 on port 1883.
1659718003: Client <unknown> closed its connection.
1659718123: New connection from 172.30.32.2:45156 on port 1883.
1659718123: Client <unknown> closed its connection.
1659718243: New connection from 172.30.32.2:45158 on port 1883.
1659718243: Client <unknown> closed its connection.
1659718363: New connection from 172.30.32.2:45160 on port 1883.
1659718363: Client <unknown> closed its connection.
1659718483: New connection from 172.30.32.2:45162 on port 1883.
1659718483: Client <unknown> closed its connection.
1659718541: Saving in-memory database to /data//mosquitto.db.
1659718603: New connection from 172.30.32.2:45164 on port 1883.
1659718603: Client <unknown> closed its connection.
1659718723: New connection from 172.30.32.2:45166 on port 1883.
1659718723: Client <unknown> closed its connection.
1659718843: New connection from 172.30.32.2:45168 on port 1883.
1659718843: Client <unknown> closed its connection.
1659718963: New connection from 172.30.32.2:45170 on port 1883.
1659718963: Client <unknown> closed its connection.
1659719083: New connection from 172.30.32.2:45172 on port 1883.
1659719083: Client <unknown> closed its connection.
1659719203: New connection from 172.30.32.2:45174 on port 1883.
1659719203: Client <unknown> closed its connection.
1659719323: New connection from 172.30.32.2:45176 on port 1883.
1659719323: Client <unknown> closed its connection.
1659719443: New connection from 172.30.32.2:45178 on port 1883.
1659719443: Client <unknown> closed its connection.
1659719563: New connection from 172.30.32.2:45180 on port 1883.
1659719563: Client <unknown> closed its connection.
1659719683: New connection from 172.30.32.2:45182 on port 1883.
1659719683: Client <unknown> closed its connection.
1659719803: New connection from 172.30.32.2:45184 on port 1883.
1659719803: Client <unknown> closed its connection.
1659719923: New connection from 172.30.32.2:45186 on port 1883.
1659719923: Client <unknown> closed its connection.
1659720043: New connection from 172.30.32.2:45188 on port 1883.
1659720043: Client <unknown> closed its connection.
1659720163: New connection from 172.30.32.2:45190 on port 1883.
1659720163: Client <unknown> closed its connection.
1659720283: New connection from 172.30.32.2:45192 on port 1883.
1659720283: Client <unknown> closed its connection.
1659720342: Saving in-memory database to /data//mosquitto.db.
1659720403: New connection from 172.30.32.2:45194 on port 1883.
1659720403: Client <unknown> closed its connection.
1659720523: New connection from 172.30.32.2:45196 on port 1883.
1659720523: Client <unknown> closed its connection.
1659720643: New connection from 172.30.32.2:45198 on port 1883.
1659720644: Client <unknown> closed its connection.
1659720764: New connection from 172.30.32.2:45200 on port 1883.
1659720764: Client <unknown> closed its connection.
1659720884: New connection from 172.30.32.2:45202 on port 1883.
1659720884: Client <unknown> closed its connection.
1659721004: New connection from 172.30.32.2:45204 on port 1883.
1659721004: Client <unknown> closed its connection.
1659721124: New connection from 172.30.32.2:45208 on port 1883.
1659721124: Client <unknown> closed its connection.
1659721244: New connection from 172.30.32.2:45210 on port 1883.
1659721244: Client <unknown> closed its connection.
1659721364: New connection from 172.30.32.2:45212 on port 1883.
1659721364: Client <unknown> closed its connection.
1659721484: New connection from 172.30.32.2:45214 on port 1883.
1659721484: Client <unknown> closed its connection.
1659721604: New connection from 172.30.32.2:45216 on port 1883.
1659721604: Client <unknown> closed its connection.
1659721724: New connection from 172.30.32.2:45218 on port 1883.
1659721724: Client <unknown> closed its connection.
1659721844: New connection from 172.30.32.2:45220 on port 1883.
1659721844: Client <unknown> closed its connection.
1659721964: New connection from 172.30.32.2:45222 on port 1883.
1659721964: Client <unknown> closed its connection.
1659722084: New connection from 172.30.32.2:45224 on port 1883.
1659722084: Client <unknown> closed its connection.
1659722143: Saving in-memory database to /data//mosquitto.db.
1659722204: New connection from 172.30.32.2:45226 on port 1883.
1659722204: Client <unknown> closed its connection.
1659722324: New connection from 172.30.32.2:45230 on port 1883.
1659722324: Client <unknown> closed its connection.
1659722444: New connection from 172.30.32.2:45232 on port 1883.
1659722444: Client <unknown> closed its connection
Mosquitto Broker config
logins: []
require_certificate: false
certfile: fullchain.pem
keyfile: privkey.pem
customize:
active: false
folder: mosquitto
Network
Change the ports on your host that are exposed by the add-on
1883/tcp
Normal MQTT
1884/tcp
MQTT over WebSocket
8883/tcp
Normal MQTT with SSL
8884/tcp
MQTT over WebSocket with SSL
I added allow_anonymous: true to the Mosquotto Broker add-on conf, no more errors, but the same …issue.
HA LOG
Full logs
2022-08-05 22:24:41.735 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-05 22:24:41.739 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nodered which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-05 22:24:41.742 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration average which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-05 22:24:41.745 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration nuki_ng which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-05 22:24:41.747 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-08-05 22:25:05.102 WARNING (MainThread) [custom_components.smartthinq_sensors] Connection not available. ThinQ platform not ready
File "/config/custom_components/smartthinq_sensors/__init__.py", line 215, in async_setup_entry
client = await lge_auth.create_client_from_token(refresh_token, oauth_url)
File "/config/custom_components/smartthinq_sensors/__init__.py", line 123, in create_client_from_token
return await ClientAsync.from_token(
File "/config/custom_components/smartthinq_sensors/wideq/core_async.py", line 1250, in from_token
gateway = await Gateway.discover(
File "/config/custom_components/smartthinq_sensors/wideq/core_async.py", line 625, in discover
gw_info = await core.gateway_info()
File "/config/custom_components/smartthinq_sensors/wideq/core_async.py", line 349, in gateway_info
return await self.thinq2_get(V2_GATEWAY_URL)
File "/config/custom_components/smartthinq_sensors/wideq/core_async.py", line 264, in thinq2_get
async with self._get_session().get(
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 1138, in __aenter__
self._resp = await self._coro
File "/usr/local/lib/python3.10/site-packages/aiohttp/client.py", line 559, in _request
await resp.start(conn)
File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 893, in start
with self._timer:
File "/usr/local/lib/python3.10/site-packages/aiohttp/helpers.py", line 721, in __exit__
raise asyncio.TimeoutError from None
asyncio.exceptions.TimeoutError
2022-08-05 22:25:05.118 WARNING (MainThread) [homeassistant.config_entries] Config entry 'LGE Devices' for smartthinq_sensors integration not ready yet: ThinQ platform not ready; Retrying in background
2022-08-05 22:25:05.136 ERROR (MainThread) [homeassistant] Error doing job: Unclosed client session
2022-08-05 22:25:05.819 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Netatmo-Presence-g2da254' for homekit_controller integration not ready yet: Timeout while waiting for connection to device 192.168.3.136:5001; Retrying in background
2022-08-05 22:25:05.824 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform samsungtv is taking over 10 seconds.
2022-08-05 22:25:05.826 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2022-08-05 22:25:05.828 WARNING (MainThread) [homeassistant.components.media_player] Setup of media_player platform dlna_dmr is taking over 10 seconds.
2022-08-05 22:25:11.297 WARNING (MainThread) [homeassistant.components.sensor] Platform netatmo not ready yet: None; Retrying in background in 30 seconds
2022-08-05 22:25:27.441 ERROR (MainThread) [homeassistant] Error doing job: Unclosed client session
2022-08-05 22:25:27.472 WARNING (MainThread) [homeassistant.components.media_player] Updating samsungtv media_player took longer than the scheduled update interval 0:00:10
2022-08-05 22:25:49.324 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid color mode received
2022-08-05 22:25:49.374 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid or incomplete color value received
2022-08-05 22:25:49.384 WARNING (MainThread) [homeassistant.components.mqtt.light.schema_json] Invalid or incomplete color value received
supervisor logs
Full logs
22-08-05 22:05:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
22-08-05 22:05:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/sabeechen/hassio-google-drive-backup repository
22-08-05 22:05:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/brenner-tobias/ha-addons repository
22-08-05 22:05:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/zigbee2mqtt/hassio-zigbee2mqtt repository
22-08-05 22:05:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
22-08-05 22:05:51 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
22-08-05 22:05:54 INFO (MainThread) [supervisor.store] Loading add-ons from store: 70 all - 0 new - 0 remove
22-08-05 22:05:56 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-08-05 22:06:23 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
22-08-05 22:06:23 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
22-08-05 22:06:23 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
22-08-05 22:06:25 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
22-08-05 22:07:49 INFO (MainThread) [supervisor.addons] Creating Home Assistant add-on data folder /data/addons/data/cebe7a76_hassio_google_drive_backup
22-08-05 22:07:49 INFO (SyncWorker_6) [supervisor.docker.interface] Downloading docker image sabeechen/hassio-google-drive-backup-aarch64 with tag 0.108.2.
22-08-05 22:08:38 INFO (MainThread) [supervisor.addons] Add-on 'cebe7a76_hassio_google_drive_backup' successfully installed
22-08-05 22:09:35 INFO (SyncWorker_7) [supervisor.docker.addon] Starting Docker add-on sabeechen/hassio-google-drive-backup-aarch64 with version 0.108.2
22-08-05 22:09:37 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from cebe7a76_hassio_google_drive_backup
22-08-05 22:09:37 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-08-05 22:09:37 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-08-05 22:09:37 INFO (MainThread) [supervisor.api.middleware.security] /backups/498be523/info access from cebe7a76_hassio_google_drive_backup
22-08-05 22:09:37 INFO (MainThread) [supervisor.api.middleware.security] /backups/d047f922/info access from cebe7a76_hassio_google_drive_backup
22-08-05 22:09:37 INFO (MainThread) [supervisor.api.middleware.security] /backups/f5479853/info access from cebe7a76_hassio_google_drive_backup
22-08-05 22:10:22 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-08-05 22:10:23 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-08-05 22:10:24 INFO (MainThread) [supervisor.api.middleware.security] /backups/498be523/download access from cebe7a76_hassio_google_drive_backup
22-08-05 22:10:24 INFO (MainThread) [supervisor.api.backups] Downloading backup 498be523
22-08-05 22:10:32 INFO (MainThread) [supervisor.api.middleware.security] /core/info access from cebe7a76_hassio_google_drive_backup
22-08-05 22:10:32 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-08-05 22:10:41 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-08-05 22:10:41 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-08-05 22:10:48 INFO (MainThread) [supervisor.api.middleware.security] /supervisor/info access from cebe7a76_hassio_google_drive_backup
22-08-05 22:10:48 INFO (MainThread) [supervisor.api.middleware.security] /backups access from cebe7a76_hassio_google_drive_backup
22-08-05 22:10:58 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-08-05 22:10:58 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-08-05 22:10:58 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/sabeechen/hassio-google-drive-backup repository
22-08-05 22:10:58 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
22-08-05 22:10:58 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
22-08-05 22:10:58 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
22-08-05 22:10:58 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/zigbee2mqtt/hassio-zigbee2mqtt repository
22-08-05 22:10:58 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/brenner-tobias/ha-addons repository
22-08-05 22:11:01 INFO (MainThread) [supervisor.store] Loading add-ons from store: 70 all - 0 new - 0 remove
22-08-05 22:11:04 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-08-05 22:16:06 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-08-05 22:21:08 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-08-05 22:23:32 WARNING (MainThread) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:23:33 INFO (SyncWorker_7) [supervisor.docker.interface] Stopping addon_core_mosquitto application
22-08-05 22:23:45 INFO (SyncWorker_7) [supervisor.docker.interface] Cleaning addon_core_mosquitto application
22-08-05 22:23:45 WARNING (MainThread) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:23:45 WARNING (SyncWorker_5) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:23:47 INFO (SyncWorker_5) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-mosquitto with version 6.1.2
22-08-05 22:23:47 WARNING (MainThread) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:23:49 WARNING (MainThread) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:23:52 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'mqtt_user'
22-08-05 22:23:53 INFO (MainThread) [supervisor.auth] Successful login for 'mqtt_user'
22-08-05 22:23:53 ERROR (MainThread) [supervisor.services.modules.mqtt] There is already a MQTT service in use from core_mosquitto
22-08-05 22:23:54 INFO (MainThread) [supervisor.auth] Auth request from 'core_mosquitto' for 'homeassistant'
22-08-05 22:23:54 WARNING (MainThread) [supervisor.auth] Unauthorized login for 'homeassistant'
22-08-05 22:24:23 INFO (SyncWorker_0) [supervisor.docker.interface] Restarting ghcr.io/home-assistant/raspberrypi4-64-homeassistant
22-08-05 22:24:23 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API error: Received message 8:1000 is not str
22-08-05 22:24:23 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API connection is closed
22-08-05 22:24:34 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
22-08-05 22:24:46 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state CoreState.RUNNING
22-08-05 22:24:47 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation complete
22-08-05 22:24:47 INFO (MainThread) [supervisor.updater] Fetching update data from https://version.home-assistant.io/stable.json
22-08-05 22:24:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/hassio-addons/repository repository
22-08-05 22:24:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/home-assistant/addons repository
22-08-05 22:24:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/esphome/home-assistant-addon repository
22-08-05 22:24:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/zigbee2mqtt/hassio-zigbee2mqtt repository
22-08-05 22:24:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/brenner-tobias/ha-addons repository
22-08-05 22:24:47 INFO (MainThread) [supervisor.store.git] Update add-on https://github.com/sabeechen/hassio-google-drive-backup repository
22-08-05 22:24:50 INFO (MainThread) [supervisor.store] Loading add-ons from store: 70 all - 0 new - 0 remove
22-08-05 22:24:52 WARNING (MainThread) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:24:52 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-08-05 22:25:11 WARNING (MainThread) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:25:15 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
22-08-05 22:25:15 INFO (MainThread) [supervisor.api.proxy] WebSocket access from a0d7b954_nodered
22-08-05 22:25:15 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
22-08-05 22:25:15 WARNING (MainThread) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:25:18 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request running
22-08-05 22:25:45 WARNING (MainThread) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:25:56 WARNING (MainThread) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:26:47 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
22-08-05 22:27:33 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-08-05 22:27:47 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-08-05 22:29:55 WARNING (MainThread) [supervisor.addons.options] Unknown option 'allow_anonymous' for Mosquitto broker (core_mosquitto)
22-08-05 22:29:55 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
22-08-05 22:30:17 WARNING (MainThread) [supervisor.addons.options] Unknown option 'base_topic' for Zigbee2MQTT (45df7312_zigbee2mqtt)
