is there anyone using the: device_sun_light_trigger from the component page automation , cause i have a problem when i turn off the lights at 23:00 the lights will turn themself back on when the time gets past 0:00. probebly because the date changes and it triggers the state that we are at home and the sun is below the horizon. is there a way to fix this??
I think the trigger is in effect always as you didn’t specify an end, you may be able to have better control by implementing an input_boolean with a scene.
yeah, that what i meant.
this was a verry useful component for me, for now i will use the input boolean.
thanks for your quick support.
Cheers, glad to help
