Device tracker alarm set help
I’m trying to create automation that will trigger my alarm to armed-away. The most accurate tracker is life 360 on my devices. The tricky part is I want a node or automation to only trigger if both life 360 devices are away. I have tried node-red but I cannot get it to take. Ideally, when one device is away it will ask if the other is away, if true, set an alarm. Then when one of the devices returns it sets the alarm to disarmed. I have come across proximity for configuration file, not sure about this one. Thank you in advance.
