I used these Device Trackers but suddenly they did not work anymore.
Device Tracker
Error message from Log.
Does anyone else have a similar problem?
Greetings
new HA
Device Tracker
Greetings
new HA
off topic
What is the range to let them detect by Bleutooth? Im searching for a solution when you alsmost near frontdoor that you can enable persons (automation) based on Bleutooth tracker.
Sorry i can’t help you with the issue.
A friend of mine uses these tokes for his door automation. I guess it’s about 6-8m range, depending on the tokens being in the bag.
But still not working. Also new activated token not detected.
