i have enabled device tracking but only the IP addresses are showing.
i see known_devices.yaml has been created. but many attempts to rename to a friendly name has failed. please help as im using 47.1
below is an example of a device. in the yaml file
so in my config yaml file, i have:
customize:
device_tracker.192168199:
friendly_name: ad blocker
i see this error in the log:
2017-07-04 18:32:44 ERROR (MainThread) [homeassistant.loader] Unable to find component customize
2017-07-04 18:32:44 ERROR (MainThread) [homeassistant.setup] Setup failed for customize: Component not found.
this works!
thank you so much for your help! the online document was not very specific.
also, not sure why winscp denied me creating a folder. i had to use putty then typed in: sudo mkdir customized
