Do you mean the logs from the Locations or the general logs?
Settings > Companion App > Troubleshooting > Show and share logs
Deleted
Here is the log
i cant read that, can you please copy and paste into pastebin or something similar so i can read it please?
Deleted
Here does that work
sorta, lots of text is missing here about the error, its cut off. Take a look at the URL in the log, does it look correct to you?
Yes the URL looks right, I think if the URL wasnât correct I wouldnât be able to access the rest of HA, right?
Ahh yes now I see it too, my phone probably didnât copy everything, Iâll upload it again from the PC
Here is the new paste, this should be complete: homeassistant_companion_log_9-20-2023_20-24-26.txt--------- beginning of main - Pastebin.com
you said you are using Nabu casa for remote access correct? Can you double check the app connection settings? It does not appear to be trying the NC URL at all.
10-20 20:17:43.176 11286 11344 E LocBroadcastReceiver: io.homeassistant.companion.android.common.data.integration.IntegrationException: java.net.SocketTimeoutException: failed to connect to /x.x.x.x (port 8123) from /x.x.x.x (port 45642) after 10000ms
Yes i use Nabu Casa, the switch for the HomeAssitant URL is on, also i can do everything else on my home assistant from remote
So the issue is that API calls are failing but the webview lets you in. If you turn the Home Assistant URL switch off does it show you an old URL by chance?
Thatâs it, I was probably lost at the time and entered the locale IP, and because everything else worked, I didnât worry about it, thank you very much
But Iâd rather delete the logs, I also think it would be really good if you could replace the IP addresses with âIP addressâ in your comment.
ok i masked them
Youre the best, I really appreciate the help
