Device tracker error after upgrading to Hassio 65.0
Getting the following error after upgrading to 65.0
2018-03-10 11:51:57 ERROR (MainThread) [homeassistant.config] Invalid config for [device_tracker]: required key not provided @ data[‘platform’]. Got None. (See ?, line ?).
Anyone else having issues, if I down grade to v64.3 all works fine!
What does your device_tracker component look like in your configuration.yaml?
65.1 should fix it
I don’t have device tracker defines in the configuration ymal, but have split configuration into a number of packages, where device tracker components are defined.
as @jwelter said, hopng 65.1 fixes the issue, in the man time just down graded to 64.3 where I have no errors.
