2020-02-09 16:30:13 WARNING (MainThread) [homeassistant.components.device_tracker] The 'hide_if_away' option (with value 'False') is deprecated, please remove it from your configuration. This option will become invalid in version 0.107.0
I searched all my files but I can’t find those lines.
I had the same thing, my known_devices kept showing up with hide_if_away: false, even after deleting the offending lines. Then I remembered my main configuration.yaml has it in the device tracker section:
Removing that last line, then cleaning hide_if_away lines from my known_devices file one more time fixed the problem for me. If you aren’t tracking a ton of devices… instead of individually deleting every single hide_if_away line from known devices, you can just delete all of the non-tracked devices wholesale, then remove the lines from the leftover devices that you are actually tracking.
This was after a bit of pruning of this file last night. Until the default is not to add “hide_if_away: false” to known_devices I see little point in worrying about it.
Yes, it’s the same with mine.
I have a Ping binary sensor, and every time a new device is added, he will automatically add this property in known_devices.yaml.
I think this is a bug and needs to be fixed.
Well now that some time has passed, I’m seeing the same as everyone else; hide_if_away keeps showing up on me. I have to agree with baz123’s observation that once hide_if_away is placed in known_devices.yaml it will keep returning, and further there is currently no workaround for this. It’s clearly a bug in the device_tracker.
A while back I read a post on github where a dev (I think frenck) mentioned that this is a known issue. IIRC, when hide_if_away was originally deprecated, they removed it and that caused some more major issues. So they reverted some of the code temporarily; this is likely the cause of this strange behavior we are seeing. Currently they have to redo a lot of things to fix hide_if_away before it can be properly removed. Apparently, deprecating hide_if_away was more complicated than they thought originally.
Kind of a related question… Where is the known_devices.yaml file located? My iPhone device_tracker is showing up twice in HA, and the only way that I can apparently remove the duplicate is in known_devices.yaml. I just don’t know where to find that file. Help please?
