Device Tracker Huawei known_devices.yaml does not create itself
Hello!
I have big problem with device tracker on huawei router HG8247
I added this line to my configuration.yaml file:
device_tracker:
  • platform: huawei_router
    host: 192.168.100.1
    username: telecomadmin
    password: admintelecom
After this known_devices.yaml file didnt create itself so i create it on my own. Before that there was a warning
Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
and
2018-12-31 02:30:28 WARNING (MainThread) [homeassistant.components.device_tracker] Updating device list from huawei_router took longer than the scheduled scan interval 0:00:12
I check what mac adresses are connected to this router and saved it to known_devices.yaml file. Problem is status of these devices is not true. Every single devices shows its not home but they are already connected. What is wrong?
Don’t add the devices manually, just create a blank file and then let your device_trackers add the devices.
I did that way. Actually i rebooted a few times router and home assistant but file is still blank, nothink shows up :frowning:
May take a while to populate the file the first time depending on how many devices are connected to the router.
I left this today, but still this file is empty :frowning: Mby sth will happend tommorow
after one day this file is still empty :frowning: any ideas?
