Device_tracker.luci Invalid response from luci: <Response [404]>
TLDR: on router; rm /tmp/luci-indexcache
Following https://home-assistant.io/components/device_tracker.luci/
I set-up on my router:
opkg install luci-mod-rpc
In my homeassistant.log I had the following error:
homeassistant.components.device_tracker.luci] Invalid response from luci: <Response [404]>
(Many google searches later and scratching of head)
On my OpenWRT router:
Restart homeassistant and now everything working.
According to the author this is solved.
I run into the same problem. I tried the proposed solution but this does not solve it for me.
Any tips would be appreciated.
Thanks,
Alex.
Having the same problem here. The only relevant lines in my log:
2017-10-29 22:43:39 ERROR (MainThread) [homeassistant.components.device_tracker] Unable to load /config/known_devices.yaml: Config file not found: /config/known_devices.yaml
2017-10-29 22:43:39 ERROR (SyncWorker_4) [homeassistant.components.device_tracker.luci] Invalid response from luci: <Response [404]>
2017-10-29 22:43:39 ERROR (MainThread) [homeassistant.components.device_tracker] Error setting up platform luci
Anyone else had this issue?
For me reinstalling luci-mod-rpc now has helped (I am not sure what I tried before, or what has changed in the repository, but i assume there has been a package update somehow, likely on the Lede-side)).
Did you install or re-install/update luci-mod-rpc on your Lede-router?
What is the output of
opkg install luci-mod-rpc?
Best,
Alex.
Hm, it did update luci-mod-rpc and luci-lib-json. So now opkg install luci-mod-rpc says it is installed and up to date:
 root@linksys:~# opkg install luci-mod-rpc
 Package luci-mod-rpc (git-17.291.51172-a98548e-1) installed in root is up to date.
Now Home Assistant doesn’t give any startup errors but every time it tries to ping luci this shows in the logs:
 2017-11-08 19:29:25 ERROR (SyncWorker_5) [homeassistant.components.device_tracker.luci] Luci responded with a 403 Invalid token
 2017-11-08 19:29:38 ERROR (SyncWorker_10) [homeassistant.components.device_tracker.luci] Luci responded with a 403 Invalid token
 2017-11-08 19:29:51 ERROR (SyncWorker_13) [homeassistant.components.device_tracker.luci] Luci responded with a 403 Invalid token
This thread may help you:
Yeah I’ve seen that thread, thanks though. Unfortunately I’m getting a different error, “Luci responded with a 403 Invalid token”, which I can’t find any information about on google.
I have same error in log with my Lede Router. But, with suggestion of another thread i now have a working device tracker
Here’s my logs:
urllib3.exceptions.ReadTimeoutError: HTTPConnectionPool(host='192.168.6.1', port=80): Read timed out. (read timeout=5)
  File "/usr/lib/python3.5/asyncio/tasks.py", line 241, in _step
    result = coro.throw(exc)
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/__init__.py", line 711, in async_device_tracker_scan
    found_devices = yield from scanner.async_scan_devices()
  File "/usr/lib/python3.5/asyncio/futures.py", line 380, in __iter__
    yield self  # This tells Task to wait for completion.
  File "/usr/lib/python3.5/asyncio/tasks.py", line 304, in _wakeup
    future.result()
  File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
    raise self._exception
  File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/luci.py",     line 64, in scan_devices
    self._update_info()
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/luci.py", line 99, in _update_info
    params={'auth': self.token})
  File "/srv/homeassistant/lib/python3.5/site-packages/homeassistant/components/device_tracker/luci.py", line 123, in _req_json_rpc
    res = requests.post(url, data=data, timeout=5, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/api.py", line 112, in post
    return request('post', url, data=data, json=json, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/api.py", line 58, in request
    return session.request(method=method, url=url, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py", line 508, in request
    resp = self.send(prep, **send_kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/sessions.py", line 618, in send
    r = adapter.send(request, **kwargs)
  File "/srv/homeassistant/lib/python3.5/site-packages/requests/adapters.py", line 521, in send
    raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPConnectionPool(host='192.168.6.1', port=80): Read timed out. (read timeout=5)
2018-01-24 11:42:04 ERROR (Thread-3) [homeassistant.components.device_tracker.luci] Luci responded with a 403 Invalid token
Did you resolved your problem?
Did you end up resolving your issue?
