Device Tracker no longer working
I’ve had my Android phone (Pixel 6a) set up as my device tracker for over a year with no issues. I left my home zone, “Home” changed to “Away” and my automations turned off lights and fans.
I made no changes, but as of 4 days ago, HA will no longer be informed that I left my home zone.
When putting the phone on the charger, this is still reported fine to HA, so the communication app/HA instance is working fine. I also see latitude and longitude data when I check the attributes of the tracker entity.
Is there anything I missed about tracker changes, or permissions that need to be changed or something? I’m using the latest stable version of HA and the HA app.
start here: Troubleshooting | Home Assistant Companion Docs
Bluetooth Tracker has been broken for a while.
search for pybluez-0-22 their are other posts about it.
I’m not using bluetooth tracking.
However, I found what caused it: For some reason, between app updates, the same domain and port redirection for the external HA URL I had been using for almost 2 years didn’t work anymore (on 2 different phones!). After re-entering the exact same data again, it started working and was able to actually send the connection data to HA.
