New to home assistant and trying to setup my Unifi Controller for presence detection. I believe I copied the tracker information correctly into the configuration.yaml file…
device_tracker:
- platform: unifi
host: 192.168.1.XXXX
port: 8443
username: HomeAssistant
password: XXXXXXXXXX
ssid_filter:- ‘XXXXXX’
- ‘XXXXXX’
I also noticed the errors below in the logs. I had to replace all the links but the first two with the word LINK as I am apparently only allowed to post two links as a new user. All the links were pretty much identical to one of the first two.
cmdline: git clone --recursive -v https://www.home-assistant.io/components/device_tracker.unifi/ /data/addons/git/b48d8caf
stderr: 'Cloning into ‘/data/addons/git/b48d8caf’…
fatal: repository ‘https://www.home-assistant.io/components/device_tracker.unifi/’ not found
18-05-10 21:40:54 ERROR (MainThread) [hassio.addons] Can’t load from repository LINK
18-05-10 21:40:54 INFO (MainThread) [hassio.addons] Load addons: 34 all - 0 new - 0 remove
18-05-10 21:42:32 INFO (MainThread) [hassio.addons.addon] Create Home-Assistant addon data folder /data/addons/data/core_configurator
18-05-10 21:42:32 INFO (SyncWorker_17) [hassio.docker.interface] Pull image homeassistant/armhf-addon-configurator tag 0.3.
18-05-10 21:42:53 INFO (SyncWorker_17) [hassio.docker.interface] Tag image homeassistant/armhf-addon-configurator with version 0.3 as latest
18-05-10 21:43:23 INFO (MainThread) [hassio.addons.git] Clone addon LINK
18-05-10 21:43:24 ERROR (MainThread) [hassio.addons.git] Can’t clone LINK repo: Cmd(‘git’) failed due to: exit code(128)
cmdline: git clone --recursive -v LINK
fatal: repository LINK not found
18-05-10 21:43:24 ERROR (MainThread) [hassio.addons] Can’t load from repository LINK
18-05-10 21:43:24 INFO (MainThread) [hassio.addons] Load addons: 34 all - 0 new - 0 remove
18-05-10 21:44:20 INFO (MainThread) [hassio.addons.git] Clone addon LINK repository
18-05-10 21:44:22 ERROR (MainThread) [hassio.addons.git] Can’t clone LINK repo: Cmd(‘git’) failed due to: exit code(128)
stderr: 'Cloning into ‘/data/addons/git/579d6181’…
I’m sure I am missing something, but I can’t figure it out. Could really use some suggestions. Thanks!
