Device Tracker not updateing GPS Location, gecodedlocation does
Settings > companion app > select your server
since its in german it reads:
Using home assistant cloud
[Name of my wifi]
Not set.
Might it be the problem that the internal connection-url is not set and should be set to the same as in the log? Also my ip 4 anf ip 6 are set to automatic, should I set it to be fixed?
can you uncheck that option and see what URL is there? I think it may show your old URL. Have you tried logging out and logging back into the app yet that may or may not work as the URL is supposed to be received automatically by HA core however there is an issue where its not getting updated at times.
The IP-adress was correct when I unchecked the option and after logging out and logging in it appears to be working! At least the two times with a fake gps Simulation, will test it tomorrow in a reallife test. Thanks for the help!
