Since updating to 0.114.3 the device tracker no longer works. No updates, no trackers showing up, known_devices.yaml does not get created or updated.
If I run a Configuration validation it spins without completing. After that, the log file shows the following:
Logger: aiohttp.server
Source: components/unifi_direct/device_tracker.py:5
First occurred: 12:03:33 PM (3 occurrences)
Last logged: 12:27:43 PM
Error handling request
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_protocol.py”, line 418, in start
resp = await task
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_app.py”, line 458, in _handle
resp = await handler(request)
File “/usr/local/lib/python3.8/site-packages/aiohttp/web_middlewares.py”, line 119, in impl
return await handler(request)
File “/usr/src/homeassistant/homeassistant/components/http/real_ip.py”, line 39, in real_ip_middleware
File “/usr/src/homeassistant/homeassistant/components/http/ban.py”, line 73, in ban_middleware
File “/usr/src/homeassistant/homeassistant/components/http/auth.py”, line 127, in auth_middleware
File “/usr/src/homeassistant/homeassistant/components/http/view.py”, line 129, in handle
result = await result
File “/usr/src/homeassistant/homeassistant/components/config/core.py”, line 29, in post
errors = await async_check_ha_config_file(request.app[“hass”])
File “/usr/src/homeassistant/homeassistant/config.py”, line 857, in async_check_ha_config_file
res = await check_config.async_check_ha_config_file(hass)
File “/usr/src/homeassistant/homeassistant/helpers/check_config.py”, line 164, in async_check_ha_config_file
platform = p_integration.get_platform(domain)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 389, in get_platform
cache[full_name] = importlib.import_module(
File “/usr/local/lib/python3.8/importlib/init.py”, line 127, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1014, in _gcd_import
File “”, line 991, in _find_and_load
File “”, line 975, in _find_and_load_unlocked
File “”, line 671, in _load_unlocked
File “”, line 783, in exec_module
File “”, line 219, in _call_with_frames_removed
File “/usr/src/homeassistant/homeassistant/components/unifi_direct/device_tracker.py”, line 5, in
from pexpect import exceptions, pxssh
File “/usr/local/lib/python3.8/site-packages/pexpect/init.py”, line 2
ID_VENDOR_FROM_DATABASE=DRS Technologies
IndentationError: unexpected indent
Any idea how to fix this?
