Device tracker showing away from home but it's within the home zone
Hello I’ve installed the iOS companion app and its sending location data to my HA server.
I can see that the device is within the home zone but it’s not registering the device is at home
I’m almost certain, that you mixed up the entity IDs.
Take a look at the “more info” of your person “Ci” and check in the attributes which entity updated your location.
So turns out you need to set the lat long of the default home zone in the YML file instead of updating the home location in the UI. Once I did that and restarted the docker container it worked
