Hi there,
playing around for some time now I had the idea to ask my router for “home” devices after having trouble with nmap (wrong or missing names).
I have some code for a markdown card, but sorting by ip gives me a headache.
{%- for state in states.device_tracker
|selectattr('entity_id', 'match','device_tracker.*')
|selectattr('state', 'eq', 'home')
|selectattr('attributes.source_type', 'eq', 'router')
|sort(attribute='attributes.ip')
{{state.attributes.ip}} | {{state.name|lower}} | {{state.attributes.mac}}
{% endfor %}
This works, but sorts in the wrong way.
192.168.111.1
192.168.111.100
192.168.111.2
192.168.111.20
192.168.111.21
192.168.111.24
192.168.111.254
192.168.111.28
192.168.111.29
192.168.111.3
192.168.111.36
and so on.
How can I split the ip address inside the for-loop and order them by the last octet?
Thanks.
WallyR
(Wally)
2
IP addresses can actually be converted to integers, which could help sorting it better.
OK, I know. But how to in this case?
Ended up using a flexible table card.
type: custom:flex-table-card
strict: true
clickable: true
sort_by: ip+
title: Network Devices
entities:
exclude:
- unknown_device
include: device_tracker.*
columns:
- name: Name
data: name
- name: IP
data: ip
- data: state
modify: (x == "home" && x) || null
hidden: true
Nevertheless it would be nice to know the other solution
Hellis81
(Hellis81)
5
Not sure if this is helpful but I managed to get this sorted:
{% set ips = ["192.168.111.1","192.168.111.100","192.168.111.2","192.168.111.20","192.168.111.21","192.168.111.24","192.168.111.254","192.168.111.28","192.168.111.29","192.168.111.3","192.168.111.36"] | map('regex_replace','(\.)','') | map('int') | sort | map('replace','192168111','192.168.111.') %}
{%- for ip in ips -%}
{{ ip }}
{% endfor %}
I assume this can be adapted to your code.
I don’t have any entities with IPs so I can’t test it on my entities, I had to make a list.
Yes, thats clear, but i want a dynamic list and can not split the attribute in sort.
