My wife just got a new mobile phone. Her phone’s geocoded location sensor is very precise.
However, the respective device_tracker just stays stuck at our “home” zone. Her device tracker should show her “work” zone (per her geocoded location),
sensor.sm_g781v_2_geocoded_location
device_tracker.sm_g781v_2
I just checked \config\.storage\core.entity_registry
its a big mess with 4-5 different varieties of the same device IDs with different names. I noticed that for many of my devices.
Is it possible that core.entity_registry
is causing this issue? If so, what is the easiest/quickest way to redo this file with only concise/correct device information. Can I just execute ha core stop
in putty, delete core.entity_registry
, then run ha core start
for the file to be re-generated cleanly?
If core.entity_registry
isn’t causing this issue, what else could it be and how do can I fix it?
