Device_tracker.template
maybe there is, maybe not…
Is there an option to have a “device_tracker.template”?
use case:
in node red and other automations I have eg. device_tracker.sm908e as my phone entity. but when I get a new phone I get a new entity.
Now when I have a template or helper that is as follows:
device_tracker.person1
  • device_tracker.sm908e
device_tracker.person2
  • device_tracker.sm501e
Is that in any way easily possible?
so in automations i use the top entity and can easily replace the device entity?
Hello sender,
This is the format for that.
You happen to have anexample because that creates a new entity yes, but I want to create an entity from another entity… dont see that there?
The action creates the entity automatically based on the value of dev_id if a matching device_tracker entity doesn’t already exist… So, if device_tracker.person_1 doesn’t exist the following will create the entity and set its state to “home”, if the tracker does exist it will just set its state to “home”:
- service: device_tracker.see
    dev_id: person_1
    location_name: home
FWIW, there is a custom integration that you may want to consider.
