I already have sensor data coming in to HA from an external http json post working perfectly.
Is there any way to do this for the device_tracker component? I have tried but no new device_tracker devices appear.
I get the following response from the http component in the logs
INFO (MainThread) [homeassistant.components.http] Serving /api/states/device_tracker.coryphone to 172.17.0.6 (auth: True)
There seems to be no errors.
My main reason for this is I am sending info on my phones state using tasker. I want to be able to track this device so as far as I can tell it has to be in device trackers. I am sending the latitude and longitude data. Currently the json data I am sending is as below {"latitude":%lonlat1,"longitude":%lonlat2}
I do something similar, I’ve used Tasker for about 3 years to send location and for the last 6 months or so send it into HA. I found the easiest way to do this was to use the gpslogger device_tracker and send the data in the format it expects.
In my case I send the data in the format I always have which goes into Node-Red and then I convert it into the format the gpslogger component expects.
