This automation is working as intended when im triggering it by hand.
However my Device Tracker isn’t triggering it and I cant figure it out myself.
Here is my known_devices.yaml
kathi_handy:
hide_if_away: false
icon:
mac:
picture:
track: true
thomas_handy:
hide_if_away: false
icon:
mac:
picture:
track: true
This is part of my configuration.yaml
group: !include groups.yaml
script: !include scripts.yaml
scene: !include scenes.yaml
zwave:
usb_path: /dev/ttyACM0
device_tracker:
- platform: ping
interval_seconds: 30
consider_home: 1200
hosts:
thomas_handy: 192.x.x.x
kathi_handy: 192.x.x.x
logger:
default: info
logs:
homeassistant.components.yamaha: critical
custom_components.my_integration: critical
and finally my automation.yaml
### Service
- id: heizung-aus
alias: 'Heizung aus'
hide_entity: False
platform: state
entity_id: device_tracker.handy_thomas
to: 'not_home'
- service: climate.set_temperature
entity_id: climate.thermostat_wohnzimmer_heating_1
temperature: 16
target_temp_high: 16
target_temp_low: 16
hvac_mode: heat
entity_id: climate.thermostat_schlafzimmer_heating_1_2
temperature: 16
target_temp_low: 16
hvac_mode: heat
entity_id: climate.thermmostat_bad_heating_1_3
temperature: 16
target_temp_low: 16
hvac_mode: heat
entity_id: climate.thermostat_kche_heating_1_4
temperature: 16
target_temp_low: 16
hvac_mode: heat
- service: persistent_notification.create
message: '{{ now().strftime("%H:%M %Y-%m-%d") }}: Heizung wird ausgeschalten'
title: "Heizung: AUS"
- id: heizung-an
alias: 'Heizung: an'
hide_entity: False
platform: state
to: 'home'
temperature: 22
target_temp_high: 22
target_temp_low: 22
hvac_mode: heat
temperature: 19
target_temp_high: 19
target_temp_low: 19
hvac_mode: heat
temperature: 22
target_temp_low: 22
hvac_mode: heat
temperature: 21
target_temp_high: 21
target_temp_low: 21
hvac_mode: heat
message: '{{ now().strftime("%H:%M %Y-%m-%d") }}: Heizung wird eingeschalten'
title: "Heizung: AN"
The ping seems to work as well, I can see when someone leaves the network the entity is shown as away.
Any ideas what I did wrong?
