This is just a simple test automation:
alias: Tracker-test
description: ""
- platform: time_pattern
minutes: /6
condition: []
- if: []
then:
- delay:
hours: 0
minutes: 2
seconds: 0
milliseconds: 0
- condition: state
for:
hours: 0
minutes: 2
seconds: 0
entity_id: device_tracker.sm_s916u
state: not_home
- service: notify.pushover
metadata: {}
message: Away for 2 min
mode: single
Trace:
"trace": {
"last_step": "action/0/then/1/entity_id/0",
"run_id": "7131fb05a61a372cb548f5d26438ed14",
"state": "stopped",
"script_execution": "finished",
"timestamp": {
"start": "2024-04-25T13:18:00.205574+00:00",
"finish": "2024-04-25T13:20:00.210751+00:00"
"domain": "automation",
"item_id": "1713824912189",
"trigger": "time pattern",
"trace": {
"trigger/0": [
"path": "trigger/0",
"timestamp": "2024-04-25T13:18:00.206027+00:00",
"changed_variables": {
"this": {
"entity_id": "automation.new_automation",
"state": "on",
"attributes": {
"id": "1713824912189",
"last_triggered": "2024-04-25T13:12:00.205471+00:00",
"mode": "single",
"current": 0,
"friendly_name": "Tracker-test"
"last_changed": "2024-04-25T12:52:56.333558+00:00",
"last_reported": "2024-04-25T13:14:00.479092+00:00",
"last_updated": "2024-04-25T13:14:00.479092+00:00",
"context": {
"id": "01HWAP8DWZE8FEP6GR2TNYTA4N",
"parent_id": null,
"user_id": null
"trigger": {
"id": "time-pat",
"idx": "0",
"alias": null,
"platform": "time_pattern",
"now": "2024-04-25T09:18:00.205357-04:00",
"description": "time pattern"
"action/0": [
"path": "action/0",
"timestamp": "2024-04-25T13:18:00.207023+00:00",
"context": {
"id": "01HWAPFR0DF72REKZJVPG4P32Y",
"parent_id": null,
"user_id": null
"result": {
"choice": "then"
"action/0/if": [
"path": "action/0/if",
"timestamp": "2024-04-25T13:18:00.207208+00:00",
"result": {
"result": true
"action/0/then/0": [
"path": "action/0/then/0",
"timestamp": "2024-04-25T13:18:00.207523+00:00",
"result": {
"delay": 120,
"done": true
"action/0/then/1": [
"path": "action/0/then/1",
"timestamp": "2024-04-25T13:20:00.209346+00:00",
"result": {
"result": false
"action/0/then/1/entity_id/0": [
"path": "action/0/then/1/entity_id/0",
"timestamp": "2024-04-25T13:20:00.209411+00:00",
"result": {
"result": false,
"state": "not_home",
"duration": "2024-04-25T13:18:00.209528+00:00"
"config": {
"alias": "Tracker-test",
"description": "",
"trigger": [
"minutes": "/6",
"id": "time-pat"
"condition": [],
"action": [
"if": [],
"then": [
"delay": {
"hours": 0,
"minutes": 2,
"seconds": 0,
"milliseconds": 0
"condition": "state",
"for": {
"hours": 0,
"minutes": 2,
"seconds": 0
"entity_id": "device_tracker.sm_s916u",
"state": "not_home"
"service": "notify.pushover",
"metadata": {},
"data": {
"message": "Away for 2 min"
"mode": "single"
"blueprint_inputs": null,
"context": {
"parent_id": null,
"user_id": null
"logbookEntries": [
"name": "Tracker-test",
"message": "triggered by time pattern",
"source": "time pattern",
"context_id": "01HWAPFR0DF72REKZJVPG4P32Y",
"when": 1714051080.2061899,
History:
entity_id state last_changed
device_tracker.sm_s916u not_home 2024-04-25T12:00:00.000Z
device_tracker.sm_s916u home 2024-04-25T13:28:06.591Z
device_tracker.sm_s916u not_home 2024-04-25T13:28:30.473Z
device_tracker.sm_s916u home 2024-04-25T13:33:04.173Z
