hi guys,
just updated to the newest version of home assistant on my pi.
since the update the device tracking using my fritz box (using wireless lan) doesn´t work anymore. the entity is always showing as unavailable.
any ideas what´s causing this?
hi guys,
Check in your entities list and see if you have a new set that need enabling.
When I updated, for some reason it added everything again (with a suffix _2 to them) and orphaned the original ones as not working.
If that’s the case, then remove the original orphaned ones and enable then rename the new ones to the older names (generally just remove the _2 from the end, unless you manually changed the names of the originals) and then things should come back.
yup, that was the problem.
thanks!
