Device tracking
How do I define weather or not a device is considered home or away. I have an ipad and iphone that I want to track. They are both current in my house but they are listed as “away”
With which integration are you tracking the state of these devices? Ping? Nmap? Something else?
Probably the ios tracker.
Define some zones. Apparently you can do it via the UI now too (configuration / zones ).
But this should be no issue when the devices are at home, because the home zone needs to be defined anyway when you setup Home Assistant or am I wrong here?
If you don’t set up a location when starting I believe the default home zone is 0 lat 0 lon (west of Gabon / Africa) which could explain the ‘away’ state.
I did setup a location when i setup homeassistant and I do have a zone defined. the other 2 devices/people i have seem to work fine.
Okay, it seems as if the issue is specifically with the ios integration…
