Qua3952
1
What can be the reason that my devices are visible while inside the “Home” zone?
It is stated on the following that
Devices that are currently at home won’t show on the map.
I’m using “owntracks” on configuration and feeding locations using Tasker and REST API.
Thanks.
Pippyn
2
So they are visible in the map located in the side menu? or in lovelace?
Did you set your home zone correctly? Can you show a screenshot?
Qua3952
3
Both on map frame and on lovelace. Here’s a print screen:
Pippyn
4
On lovelace this is normal, but on the map it shoudn’t show. Strange…
What version of HA are you using?
Qua3952
5
0.87.1 - but it’s like that for long time maybe even since I set it up, I only now decided to look at it…
