Hi there,
i amnew at home assistant and now i have my first problem. I have an Ikea Tradfri bulb that i want to connect. Zigbee2mqtt found the device but i doesnt support. Other simmilar bulbs work perfectly. Now i want to remove the device but that raise an error. Here is my Zipbee2mqtt protokoll:
Zigbee2MQTT:info 2023-01-29 14:58:21: Removing device '0x000d6ffffe1f14d0' (block: false, force: false)
Zigbee2MQTT:error 2023-01-29 14:58:31: Request 'zigbee2mqtt/bridge/request/device/remove' failed with error: 'Failed to remove device '0x000d6ffffe1f14d0' (block: false, force: false) (Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms)'
Zigbee2MQTT:info 2023-01-29 14:58:31: MQTT publish: topic 'zigbee2mqtt/bridge/response/device/remove', payload '{"data":{},"error":"Failed to remove device '0x000d6ffffe1f14d0' (block: false, force: false) (Error: AREQ - ZDO - mgmtLeaveRsp after 10000ms)","status":"error","transaction":"9vwes-1"}'
Anyone can help?
