Devices not recognized in ZHA
i am using the ZHA integration for the first time and i am having issues adding devices. i am using the ZHA integration with sonoff zigbee 3.0 USB Dongle plus. the coordinator is getting added without any issues but i am not able to add any devices. i have tried pairing the hue dimmer switch, hue dimmer switch v2 and ikea tradfri blubs but none of them get recognized… i get the following message in the log window. any help would be much appreciated. Thank you.
2022-03-30 21:29:56 INFO (MainThread) [zigpy_znp.zigbee.application] Permitting joins for 60 seconds
2022-03-30 21:29:56 DEBUG (MainThread) [zigpy_znp.api] Sending request: ZDO.MgmtPermitJoinReq.Req(AddrMode=<AddrMode.Broadcast: 15>, Dst=0xFFFC, Duration=60, TCSignificance=0)
2022-03-30 21:29:56 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.MgmtPermitJoinReq.Rsp(Status=<Status.SUCCESS: 0>)
2022-03-30 21:29:56 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.MgmtPermitJoinRsp.Callback(Src=0x0000, Status=<Status.SUCCESS: 0>)
2022-03-30 21:29:56 DEBUG (MainThread) [zigpy_znp.api] Received command: ZDO.MsgCbIncoming.Callback(Src=0x0000, IsBroadcast=<Bool.false: 0>, ClusterId=32822, SecurityUse=0, TSN=9, MacDst=0x0000, Data=b'\x00')
2022-03-30 21:29:56 DEBUG (MainThread) [zigpy_znp.api] Sending request: AF.DataRequestExt.Req(DstAddrModeAddress=AddrModeAddress(mode=<AddrMode.Broadcast: 15>, address=0xFFFC), DstEndpoint=0, DstPanId=0x0000, SrcEndpoint=0, ClusterId=54, TSN=7, Options=<TransmitOptions.NONE: 0>, Radius=0, Data=b'\x07\x3C\x00')
2022-03-30 21:29:56 DEBUG (MainThread) [zigpy.zdo] [0x0000:zdo] ZDO request ZDOCmd.Mgmt_Permit_Joining_rsp: [<Status.SUCCESS: 0>]
2022-03-30 21:29:56 DEBUG (MainThread) [zigpy.zdo] [0x0000:zdo] No handler for ZDO request:ZDOCmd.Mgmt_Permit_Joining_rsp([<Status.SUCCESS: 0>])
2022-03-30 21:29:56 DEBUG (MainThread) [zigpy_znp.api] Received command: AF.DataRequestExt.Rsp(Status=<Status.SUCCESS: 0>)
2022-03-30 21:29:59 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2022-03-30 21:29:59 DEBUG (MainThread) [zigpy_znp.api] Received command: SYS.Ping.Rsp(Capabilities=<MTCapabilities.APP_CNF|GP|UTIL|ZDO|AF|SYS: 1625>)
2022-03-30 21:30:29 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2022-03-30 21:30:29 DEBUG (MainThread) [zigpy_znp.api] Received command: SYS.Ping.Rsp(Capabilities=<MTCapabilities.APP_CNF|GP|UTIL|ZDO|AF|SYS: 1625>)
2022-03-30 21:30:59 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2022-03-30 21:30:59 DEBUG (MainThread) [zigpy_znp.api] Received command: SYS.Ping.Rsp(Capabilities=<MTCapabilities.APP_CNF|GP|UTIL|ZDO|AF|SYS: 1625>)
2022-03-30 21:31:29 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2022-03-30 21:31:29 DEBUG (MainThread) [zigpy_znp.api] Received command: SYS.Ping.Rsp(Capabilities=<MTCapabilities.APP_CNF|GP|UTIL|ZDO|AF|SYS: 1625>)
FYI, basic troubleshooting tips here:
https://www.home-assistant.io/integrations/zha#best-practices-to-avoid-pairingconnection-difficulties
and more here:
https://github.com/home-assistant/home-assistant.io/pull/18864
https://github.com/home-assistant/home-assistant.io/commit/970295a277e8f01d3ee39eeeaacf453625b988d3
