Devolo Magic 1 WiFi mini does not show up in integration
I have a rather strange thing going on with one of my Devolo Magic 1 WiFi mini’s.
To give you a complete picture;
Home Assistant 2023.7.3
Supervisor 2023.07.1
Frontend 20230705.1 - latest
For a while now I have the Devolo integration working without issues and consists of:
1 Magic 2 LAN DINrail
1 Magic 1 WiFi 2-1
2 Magic 1 WiFi mini
The network works fine, Wifi devices are connected, all Devolo’s are configured and communicate amongst each other.
Thing is, one of the WiFi mini’s doesnt show up in HA, no matter what. I have no idea what is wrong or how to solve it. I’ve tried everything…restart, reset, reconfigure. I tried manually adding it to the integration, but after adding the device’s IP, HA says ‘Failed to connect’. Connection to the mini’s web interface using the same IP is no problem…everything works.
Anyone ever experienced something similar and know how to solve it??
Problem solved by removing the integration in it’s whole, a re-pairing of all Devolo devices and a HA reboot. 2 out of 4 devices were detected straight away, the others came up after doing anoter reboot of the missing Devolo device in question. Must have been something wrong with the integration als the whole Devolo network was working just fine.
