A few days ago, I changed the password to my Dexcom.com account. I expected Home Assistant to lose connection and become “Unavailable”. No problem, just update the password on the Dexcom configuration.
Problem… I can’t find how to do this. Where are the Dexcom login credentials stored?
Temporary solution- change the Dexcom.com password back to the original. But, the Dexcom sensor is still “unable”.
It’s supposed to be off limits, but some integrations were migrated to UI without proper thinking, and do not allow basic capabilities such as changing user/password or API keys.
The “proper” way is to remove and reinstall the integration, but hey, are we tinkerers or are we not
Interesting question. I am guessing that you are using the File Editor add-on. Until you asked, I did not know that the editor add-on does not expose hidden files or folders. And I don’t see a way to change that.
I use the Samba add-on and do all my editing on my PC. The PC doesn’t recognize the Linux method of hiding files or folders by starting the name with a dot, so my editor on the PC has no problem opening it.
I never use Studio Code Server - too complex. I just use Notepad++ on my PC. After installing the Samba Share add-on, you should see this on your PC’s File Manager:
thank you for trying to help. I installed it but I can’t locate it on my PC. Is deleting the dexcom integration and reinstalling it an option? I’m worried I am going to lose all of my custom automations if I delete it
