I built a children audio playback device based on esphome and DF-player mini. Everything works fine, but I can not find a way to stop playback at the end of the folder (I have multiple audio books on the SD card). I can only loop the playback of one folder indefintely (which will be anoying) or play a single file from the folder.
At least in my experients this did not work out, since you need to specify a folder and a file. Then it plays the the single file and stops then. The alternative is to play a folder but then it loops the entire folder.
However, I found a solution by playing one song after the other by increasing the file number after each “Playback done” event until I get a Nack due to a non present file. Therefore I needed to fix the DFplayer code - MR is on its way: Added Handling for Nack "file not found" by croessi · Pull Request #5338 · esphome/esphome · GitHub
If anybody is interested I can share the esphome yaml as soon as the MR is in.
