DFPlayer and Iobroker
Hello, I use ESPHome through my iobroker. I have a DFPlayer connected to a Wemos D1 Mini.
I flashed the YAML, but how do I control the DFPlayer?
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
  level: VERBOSE
uart:
  tx_pin: GPIO1
  rx_pin: GPIO3
  baud_rate: 9600
wifi:
  ssid: !secret wifi_ssid
web_server:
  port: 80
dfplayer:
  on_finished_playback:
    then:
      logger.log: 'Playback finished event'
api:
  services:
  - service: dfplayer_next
    then:
      - dfplayer.play_next:
  - service: dfplayer_previous
    then:
      - dfplayer.play_previous:
  - service: dfplayer_play
    variables:
      file: int
    then:
      - dfplayer.play: !lambda 'return file;'
  - service: dfplayer_play_loop
    variables:
      file: int
      loop_: bool
    then:
      - dfplayer.play:
          file: !lambda 'return file;'
          loop: !lambda 'return loop_;'
  - service: dfplayer_play_folder
    variables:
      folder: int
      file: int
    then:
      - dfplayer.play_folder:
          folder: !lambda 'return folder;'
  - service: dfplayer_play_loop_folder
    variables:
      folder: int
    then:
          loop: true
  - service: dfplayer_set_device_tf
    then:
      - dfplayer.set_device: TF_CARD
  - service: dfplayer_set_device_usb
    then:
      - dfplayer.set_device: USB
  - service: dfplayer_set_volume
    variables:
      volume: int
    then:
      - dfplayer.set_volume: !lambda 'return volume;'
  - service: dfplayer_set_eq
    variables:
      preset: int
    then:
      - dfplayer.set_eq: !lambda 'return static_cast<dfplayer::EqPreset>(preset);'
  - service: dfplayer_sleep
    then:
      - dfplayer.sleep
  - service: dfplayer_reset
    then:
      - dfplayer.reset
  - service: dfplayer_start
    then:
      - dfplayer.start
  - service: dfplayer_pause
    then:
      - dfplayer.pause
  - service: dfplayer_stop
    then:
      - dfplayer.stop
  - service: dfplayer_random
    then:
      - dfplayer.random
  - service: dfplayer_volume_up
    then:
      - dfplayer.volume_up
  - service: dfplayer_volume_down
    then:
      - dfplayer.volume_down
I hoped that the variables would be shown to me when the API is active.
Go to developer tools → services.
There should be a service for each of the “stuff” you placed under api: in the yaml.
iobroker is not HA. The answer is, I have no idea.
ahh…
I didn’t get what OP meant.
Perhaps if you enable web server on the device you can use the webpage on the devices IP.
Is this the integration you have used? GitHub - DrozmotiX/ioBroker.esphome: Control your ESP8266/ESP32 with simple yet powerful configuration files created and managed by ESPHome
Wow. Isn’t it a bit scary to see how ESPHome creeps into other Home Automation systems and builds up pressure to migrate to HA? :laughing:
It seems from my reading that the underlying API does not yet support services, but I may be misreading or reading in the wrong place. The OP hasn’t replied that the integration I found is the one he is using.
Yes exactly, I used this tool for that.
So far everything that I have used has worked, only the DFPlayer does not show any control variables.
I’m sorry for my bad English.
Yes, I think it’s great because you can choose the best one. All very great work, no matter which system.
@Tobi78 no problem with your English.
As far as I can tell GitHub - DrozmotiX/ioBroker.esphome: Control your ESP8266/ESP32 with simple yet powerful configuration files created and managed by ESPHome (an ioBroker implementation of esphome) depends on GitHub - Nafaya/esphome-native-api (a nodescript implenentation of the esphome API). However esphome-native-api does not seem to implement services - see please add HomeAssistent service (get and command) · Issue #17 · Nafaya/esphome-native-api · GitHub
Quite what the solution is without access to services I am unsure. Perhaps ask on either of those githubs.
Maybe by using template buttons/swiches within esphome to get the functions exposed @Tobi78
It would be enough for me if I could address him via IP, for example:
http://192.168.178.174/cm?cmnd=MP3Track3
That may be possible, I don’t have a dfplayer to try. See the api that the web server exposes
Sorry Nick, but I think this would rather be done through the HTTP Request component using a http_request.get or http_request.send action.
If needed you could use a lambda to build the DFPlayer URL including any variables in query string parameters.
As I understand it, the http_request is to send an http_request FROM the esp device, whereas we are trying send a request TO the esp device.
Oh, if that’s the case then you are definitely correct!
Reading @Tobi78’s comment again I am still not sure which of these two options he is talking about.
I’m sorry, I’m not that deep into the topic.
I actually just want to control the player from my IoBroker via the ESPHome tool.
since there are no controls, I thought you could do it with the command http://192.168.178.174/ Play Track 1.
But I don’t know exactly what I would have to enter for it.
MQTT seems to be a way to do it.
MQTT Client Component — ESPHome
No experience of it though.
Still not clear to me:
Is 192.168.178.174 the IP of your ESP or of your DFPlayer? I don’t know this player so I cannot conclude if these are HTTP request that your player understands or request endpoints that you want to implement to control your ESP.
The DF-player is a small component you connect to an arduino or ESP.
So I would assume the IP is the ESP since there is not IP on the DF-player since it is connected with UART.
DF-Player mini — ESPHome
