The addon_core_dhcp_server utilizes the standard ISC DHCP server which supports the full DHCP standard.
The only issue is the HA’s code that enumerates/converts YAML into the dhcpd.conf, only accepts three named parameter for each host (ip, mac, name).
This makes sense because it’s a hassle to predict the alternative options and name them all.
However, if the user would like to specify other DHCP options, such as Option 66 (TFTP Server), it makes sense to allow them as it’s the standard and supported by the ISC server.
A simple option is to alter the YAML enumeration (the for host in (bashio:config) loop in the /run.sh script).
This can be valuable for users who need to use TFTP for flashing bricked devices, etc.
I’m not requesting a new feature. I’m simply sharing a simple explanation and code, in the event the HA developers are interested in adding it.
Thank you.
# Create DHCP Hosts by enumerating Host List & Keys (IP, MAC, Name, or DHCP Option)
for host in $(bashio::config 'hosts|keys'); do
NAME=$(bashio::config "hosts[${host}].name")
echo "host ${NAME} {"
# Iterate all Hosts
for key in $(bashio::config "hosts[${host}]|keys"); do
VALUE=$(bashio::config "hosts[${host}].${key}")
# Validate: Named options
if [[ "${key}" == "ip" ]]; then
echo " fixed-address ${VALUE};"
elif [[ "${key}" == "mac" ]]; then
echo " hardware ethernet ${VALUE};"
# Validate: Numeric DHCP Option
elif [[ "${key}" =~ ^[0-9]+$ ]]; then
if (( key > 0 && key < 255 )); then
echo " option ${key} ${VALUE};"
fi
fi
done
echo "}"
} >> "${CONFIG}"
done
I received the impression that the community didn’t see any need for the improvement and I thought that I’d save a couple hours of documentation edits and general logistics with a first time contribution – in the event that community members intentionally removed the original DHCP features.
Although to be fair, it also (implicitly) corrects a minor issue where the hostname is added improperly.
At your suggestion I went forward with the pull request and documented. I’ve added example usage in the hope it might help others understand how this can be useful Home Assistant deployments.
