Hi there!
Sorry for my question, I’m a newbie in Homeassistant =)
I have a DHT22 sensor and there was all worked until I have issued a “sudo apt-get upgrade” command and following reboot.
Now I can see an “object not found” label in lovelace.
I can’t add any card with object “sensor.kitchen”, cause I haven’t see that in list of available sensors.
This is my configuration.yaml code:
- platform: command_line
name: Pi temperature
command: "cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: " C"
value_template: '{{ value | multiply(0.001) | round(1) }}'
- platform: dht
sensor: DHT22
pin: 4
monitored_conditions:
- temperature
- humidity
All other sensors, exclude dht22 on pin4, working well…
Meanwhile, hass --script check_config
don’t shows me any errors:
homeassistant@raspberrypi:~/.homeassistant $ hass --script check_config
Testing configuration at /home/homeassistant/.homeassistant
And finally, I run a py script and there my dht22 board running well and shows me a correct values.
So, I need help to fix it, guys!
Thank you!
upd. Here is a log of Home assistant:
dht: Error on device update!
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity_platform.py”, line 319, in _async_add_entity
await entity.async_device_update(warning=False)
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/helpers/entity.py”, line 466, in async_device_update
self.update # type: ignore
File “/usr/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/dht/sensor.py”, line 137, in update
self.dht_client.update()
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/util/init.py”, line 239, in wrapper
result = method(*args, **kwargs)
File “/srv/homeassistant/lib/python3.7/site-packages/homeassistant/components/dht/sensor.py”, line 173, in update
humidity, temperature = self.adafruit_dht.read_retry(self.sensor, self.pin)
File “/srv/homeassistant/lib/python3.7/site-packages/Adafruit_DHT/common.py”, line 94, in read_retry
humidity, temperature = read(sensor, pin, platform)
File “/srv/homeassistant/lib/python3.7/site-packages/Adafruit_DHT/common.py”, line 80, in read
platform = get_platform()
File “/srv/homeassistant/lib/python3.7/site-packages/Adafruit_DHT/common.py”, line 60, in get_platform
from . import Beaglebone_Black
File “/srv/homeassistant/lib/python3.7/site-packages/Adafruit_DHT/Beaglebone_Black.py”, line 24, in
from . import Beaglebone_Black_Driver as driver
ImportError: cannot import name ‘Beaglebone_Black_Driver’ from ‘Adafruit_DHT’ (/srv/homeassistant/lib/python3.7/site-packages/Adafruit_DHT/init.py)
