After updating to 0.51.2 - Hassio - I was having an issue with my dht sensor where temperature or humidity would display after restarts but not both.
Did a new install of Hassio and have a different issue now. After configuring the dht sensor and restarting Home Assistant I get the error that follows at startup. Have seen a solution for the version of this issue that occurs after updating Home Assistant, but have not been able to find anything as relates to the issue when doing a new installation. Any assistance/direction appreciated.
2017-08-19 07:36:48 ERROR (SyncWorker_0) [homeassistant.util.package] Unable to install package https://github.com/adafruit/Adafruit_Python_DHT/archive/da8cddf7fb629c1ef4f046ca44f42523c9cf2d11.zip#Adafruit_DHT==1.3.2: Command “/usr/bin/python3 -u -c “import setuptools, tokenize;file=’/tmp/pip-dyr4_bsg-build/setup.py’;f=getattr(tokenize, ‘open’, open)(file);code=f.read().replace(’\r\n’, ‘\n’);f.close();exec(compile(code, file, ‘exec’))” install --record /tmp/pip-ugt_7zc9-record/install-record.txt --single-version-externally-managed --prefix --compile --user --prefix=” failed with error code 1 in /tmp/pip-dyr4_bsg-build/
2017-08-19 07:36:48 ERROR (MainThread) [homeassistant.setup] Not initializing sensor.dht because could not install dependency https://github.com/adafruit/Adafruit_Python_DHT/archive/da8cddf7fb629c1ef4f046ca44f42523c9cf2d11.zip#Adafruit_DHT==1.3.2
2017-08-19 07:36:48 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform sensor.dht: Could not install all requirements.
