DHT11 (attached to ESP8266 and flashed with Tasmota) sensor values not showing up in Home Assistant
I flashed Tasmota on Nodemcu. Attached a 4 channel relay and a DHT11 sensor. It shows up fine on the browser. I can see the sensor outputs and can control the relays. However, from HA, I can only control the relays but don’t see the output of the sensors.
Below is my entry in the configuration.yaml file. I took it from the Tasmota wiki https://github.com/arendst/Sonoff-Tasmota/wiki/Home-Assistant-%E2%80%90-Manual-Config
  - platform: mqtt
    state_topic: "tele/sonoff/SENSOR"
    value_template: "{{ value_json['DHT22'].Temperature }}"
    unit_of_measurement: "°C"
    availability_topic: "tele/sonoff/LWT"
    payload_available: "Online"
    payload_not_available: "Offline"
  - platform: mqtt
    value_template: "{{ value_json['DHT22'].Humidity }}"
    unit_of_measurement: "%"
Below is the console output from Tasmota:
21:45:29 MQT: tele/sonoff/SENSOR = {"Time":"2019-03-31T21:45:29","DHT11":{"Temperature":31.3,"Humidity":43.0},"TempUnit":"C"}
Tasmota screenshot showing Temperature and Humidity alongwith relay status.
HA screenshot showing the relays (under Switch) but not the sensor output
What could I be missing?
Change your sensor from DHT22 to DHT11 as per the json string.
value_template: "{{ value_json['DHT11'].Temperature }}"
Do the same for the humidity sensor.
My bad. I had directly pasted it from the tasmota wiki. My actual configurations are
value_template: “{{ value_json[‘DHT11’].Temperature }}”
and
value_template: “{{ value_json[‘DHT11’].Humidity }}”
Still not working.
The same problem over here …
So, I got it resolved. Though I can’t explain why. There was a line in the config.yaml file which was throwing a warning (completely unrelated). Removing that solved the issue.
Thus, the config in the documentation should be working right.
Can you paste your configuration and the output from the Tasmota console?
output from Tasmota :
12:08:27 MQT: tele/sonoffTH/STATE = {“Time”:“2019-04-03T12:08:27”,“Uptime”:“1T22:02:27”,“Vcc”:2.714,“SleepMode”:“Dynamic”,“Sleep”:50,“LoadAvg”:21,“Wifi”:{“AP”:1,“SSId”:“MEO-HRM”,“BSSId”:“00:06:91:4C:0D:40”,“Channel”:1,“RSSI”:100,“LinkCount”:1,“Downtime”:“0T00:00:04”}}
12:08:27 MQT: tele/sonoffTH/SENSOR = {“Time”:“2019-04-03T12:08:27”,“DHT11”:{“Temperature”:24.9,“Humidity”:37.0},“TempUnit”:“C”}
configuration from yaml file:
  • platform: mqtt
    state_topic: “tele/sonoffTH/SENSOR”
    name: "Temperatura Sala "
    icon: mdi:thermometer
    availability_topic: “tele/sonoffTH/SENSOR”
    unit_of_measurement: °C
    payload_available: “Online”
    payload_not_available: “Offline”
  • platform: mqtt
    name: "Humidade Sala "
    icon: mdi:water-percent
    unit_of_measurement: ‘%’
{{value_json.DHT11.Temperature}}
Replace with following code. Its working.
  - platform: mqtt
    name: "Bedroom Temperature"
    state_topic: "tele/testlamps/SENSOR"
    # Change testlamps with MQTT topic given in Tasmota Configuration/Configure MQTT WUI
    # Change DHT11 with your actual sensor name like DHT22, AM2301 etc.
    unit_of_measurement: "°C"  # "F" if using Fahrenheit
    availability_topic: "tele/testlamps/LWT"
    device_class: temperature
Hit like if it worked for you !!! :slight_smile:
