I’m a new user with Home Assistant, I use Domoticz since a long. I try to configure my Wemos D1 with MQTT and Home Assistant.
I can see the connection with the internal MQTT Broker in the log with the Wemos. But I can read value in a card (Lovelace)…
There is my configuration in yaml.configuration:
mqtt:
broker: 192.168.1.29
- platform: mqtt
state_topic: lampe/DHT/Temperature
unit_of_measurement: "°C"
- platform: mqtt
state_topic: lampe/DHT/Humidity
unit_of_measurement: "%"
And the log of the MQTT Broker:
1573269760: New connection from 192.168.1.44 on port 1883.
The configuration with my Wemos ESPEasy:
Thanks for your help
francisp
(Francis)
November 9, 2019, 4:36am
2
What messages do you see in e.g MQTT-fx, MQTT Explorer or MQTT Lens ?
It seems I have a problem with ESPEasy, in the log I see:
842237: WD : Uptime 14 ConnectFailures 0 FreeMem 21520 WiFiStatus 3
857137: MQTT : Intentional reconnect
857267: MQTT : Failed to connect to broker
I try with mqtt explorer and nothing appear from my Wemos, but I am able to publish from a terminal.
BertrumUK
(Neil B)
November 9, 2019, 7:15am
4
Here are my MQTT and ESP settings for a DS18B20 temperature sensor. You need to make sure that “send data” is ticked so that your readings are sent to your broker.
I notice your ESP is not picking up a temperature reading which is strange as the Humidity is showing - could be a faulty DHT.
If you ever have time and a wemos left, give esphome a try.
Thanks for your reply.
I forgot the user and password in the espeasy… Now my 2 espeasy are connected. And I see the Humidity and Temperature of my Chicken House. !
