Hey , i want unable to get DHT22 sensor to work,
log indicate installation problem, anyone managed to solve it?
'''Unable to install package Adafruit-DHT==1.4.0: WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb5479598>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/adafruit-dht/ WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb54796d0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/adafruit-dht/ WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb54797a8>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/adafruit-dht/ WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb5479880>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/adafruit-dht/ WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb5479958>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/adafruit-dht/ WARNING: Retrying (Retry(total=4, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb5479c40>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/adafruit-dht/ WARNING: Retrying (Retry(total=3, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb5479d18>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/adafruit-dht/ WARNING: Retrying (Retry(total=2, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb5479df0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/adafruit-dht/ WARNING: Retrying (Retry(total=1, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb5479ec8>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/adafruit-dht/ WARNING: Retrying (Retry(total=0, connect=None, read=None, redirect=None, status=None)) after connection broken by 'NewConnectionError('<urllib3.connection.HTTPSConnection object at 0xb5479fa0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution')': /simple/adafruit-dht/ ERROR: Could not find a version that satisfies the requirement Adafruit-DHT==1.4.0 ERROR: No matching distribution found for Adafruit-DHT==1.4.0
7:27:33 AM – util/package.py (ERROR)
