DHT22 shows Humidity 1% temperature is OK
Before I submit the below as issue I want to check if the problem is somewhere else…
I am running HA on AIO Intallation on RP3, HA ver. 0.58.1 which is the latest version at the moment I am writing this post.
A DHT22 sensor is plugged into RP3 (port 23) - It was working great for 1 year already, but recently after I moved from 0.48 to 0.58 and configured HomeBridge I noticed this strange behavior:
  • Temperature shows correctly as always;
  • Humidity stays frozen at 1%.
    What is even more interesting:
  • if I reboot the RP3, I can see the humidity showing expected %, but about 10 seconds after that it goes again to 1%.
  • If I breath into it, I can also see changes in humidity, but again, after few seconds it switches instantly to 1%.
  • AND… to get it even more complicated, at the same time the HomeBridge works fine for all my devices and I can use SIRI, etc, BUT, the reading in HomeBridge for that humidity sensor shows 23% more than the HA shows on the UI, i.e. the HA shows 1%, Homebridge shows at the same time 24% (which 24% I tend to believe is the correct value for that room at the moment). Homebridge shows the same temperature as HA for that DHT sensor. The issue is with humidity only.
I know and I read some issues of humidity/temperature on DHT sensors after 0.50, but then I checked my version 0.58.1 has these issues fixed.
Also tried with no effect: rebooting the RP3 without the sensor wired and then with; Deleting the whole HA database, playing with humidity_offset parameter in config - it just adds that offset to the 1% value of the humidity - and this offset also goes to the HomeBridge.
HUMIDITY = 1% in HA >>>>>> 24% in HomeBridge
with humidity_offset = 30:
HUMIDITY = 31% in HA >>>>>> 54% in HomeBridge, and so on …
I would appreciate some advise here (unfortunately I don’t have spare DHT22, and I don’t think is hardware issue - I haven’t changed anything for 1+ years in terms of hardware and wiring).
Ok, I got new DHT22 and it is the same issue. No one with the same issues?
Probably not :slight_smile:
How is your sensor connected?
Do you use the resistor?
Can you try the sensors with an esp8266 (or other supported) board?
It turned out weak cable connector to the breadboard. Thank you all!
