# more home-assistant.log|grep dht
➜ config git:(master) ✗ more home-assistant.log|grep dht
2020-12-15 13:28:47 INFO (SyncWorker_1) [homeassistant.loader] Loaded dht from homeassistant.components.dht
2020-12-15 13:28:48 INFO (MainThread) [homeassistant.components.sensor] Setting up sensor.dht
2020-12-15 13:28:50 ERROR (MainThread) [homeassistant.components.sensor] dht: Error on device update!
File "/usr/src/homeassistant/homeassistant/components/dht/sensor.py", line 137, in update
self.dht_client.update()
File "/usr/src/homeassistant/homeassistant/components/dht/sensor.py", line 173, in update
humidity, temperature = self.adafruit_dht.read_retry(self.sensor, self.pin)
2020-12-15 13:28:51 ERROR (MainThread) [homeassistant.components.sensor] dht: Error on device update!
Mine was fine but stopped working when I installed OS 5.8.
I get this message:
File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 359, in _async_add_entity
await entity.async_device_update(warning=False)
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 466, in async_device_update
await task
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/util/__init__.py", line 239, in wrapper
result = method(*args, **kwargs)
File "/usr/local/lib/python3.8/site-packages/Adafruit_DHT/common.py", line 94, in read_retry
humidity, temperature = read(sensor, pin, platform)
File "/usr/local/lib/python3.8/site-packages/Adafruit_DHT/common.py", line 80, in read
platform = get_platform()
File "/usr/local/lib/python3.8/site-packages/Adafruit_DHT/common.py", line 63, in get_platform
raise RuntimeError('Unknown platform.')
RuntimeError: Unknown platform.
Same exact problem as yours with the same LOG.
Before 2020.12 update. it worked without problems.
I hope it will be solved as all my automations based on external environmental parameters are affected by this sensor.
