Hi all,
Long-time HA / HAOS user here running on an RPi4 + SSD and am generally happy with the performance, even allowing for the relatively modest performance of the device. But at some point over the last 6 months, my boot performance has fallen off a cliff and reboots gone from taking 30 seconds, to taking 10 minutes+. I’ve added a few integrations, for sure, and the RPi is doing a bit of work in the background, but I’d like to understand if the problem is one of configuration, a ropey integration or just having outgrown the RPi.
I could just start disabling integrations until I find the rogue one, but is there a more scientific way to diagnose slow boots?
A snip from the most recent boot log:
2023-03-01 22:05:28.425 WARNING (MainThread) [homeassistant.setup] Setup of input_text is taking over 10 seconds.
2023-03-01 22:05:28.428 WARNING (MainThread) [homeassistant.setup] Setup of input_datetime is taking over 10 seconds.
2023-03-01 22:05:28.430 WARNING (MainThread) [homeassistant.setup] Setup of input_button is taking over 10 seconds.
2023-03-01 22:05:28.432 WARNING (MainThread) [homeassistant.setup] Setup of counter is taking over 10 seconds.
2023-03-01 22:05:28.433 WARNING (MainThread) [homeassistant.setup] Setup of input_select is taking over 10 seconds.
2023-03-01 22:05:28.434 WARNING (MainThread) [homeassistant.setup] Setup of input_boolean is taking over 10 seconds.
2023-03-01 22:05:28.435 WARNING (MainThread) [homeassistant.components.scene] Setup of scene platform homeassistant is taking over 10 seconds.
2023-03-01 22:05:28.436 WARNING (MainThread) [homeassistant.setup] Setup of input_number is taking over 10 seconds.
2023-03-01 22:05:28.438 WARNING (MainThread) [homeassistant.setup] Setup of timer is taking over 10 seconds.
2023-03-01 22:05:28.440 WARNING (MainThread) [homeassistant.setup] Setup of schedule is taking over 10 seconds.
2023-03-01 22:05:28.442 WARNING (MainThread) [homeassistant.setup] Setup of group is taking over 10 seconds.
2023-03-01 22:05:28.443 WARNING (MainThread) [homeassistant.setup] Setup of application_credentials is taking over 10 seconds.
2023-03-01 22:05:28.444 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform uptime is taking over 10 seconds.
2023-03-01 22:05:28.446 WARNING (MainThread) [homeassistant.setup] Setup of proximity is taking over 10 seconds.
2023-03-01 22:05:28.593 WARNING (MainThread) [homeassistant.components.sensor] Updating command_line sensor took longer than the scheduled update interval 0:00:10
2023-03-01 22:05:28.624 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform template is taking over 10 seconds.
2023-03-01 22:05:28.631 WARNING (MainThread) [homeassistant.components.threshold.binary_sensor] State is not numerical
2023-03-01 22:05:29.036 WARNING (MainThread) [homeassistant.components.light] Setup of light platform switch is taking over 10 seconds.
If I had to point at an obvious cause, it’s this:
2023-03-01 22:10:14.200 WARNING (MainThread) [homeassistant.bootstrap] Waiting on integrations to complete setup: raspberry_pi
…which was repeated several times in the logs over the course of several minutes of boot time.
Any thoughts from anyone?
