Diagnosing Performance Issues
I am seeing high CPU (100% on one core) and related instability from homeassistant. I am running homeassistant 2022.5.3 on a Ubuntu machine with kernel 5.4.0-109 64 bit. This in Intel i7 4 core CPU and 16GB RAM with 256GB SSD. Everything was working fine until 2022.5. Only other change is new SSL certs but everything was working after these were loaded. Where can I look to determine what could be causing this? Also have HACS installed, as well as NodeRed. These seem ok. No majore changes here.
thanks
George
Hopefully related and done with 2022.5.4: Abrupt steep ascent of processor use and temperature · Issue #71387 · home-assistant/core · GitHub
You still need to supply the requested py-spy file or they will have no idea what is causing it.
Thanks All,
Once 5.4 is applied, I’ll see if issue is resolved, else will py-spy the heck out of it once I find out what py-spy is.
gb
See that big green “open” label on the issue?
That means it hasn’t been fixed yet. And it wont be unless one of you supplies the requested py-spy output file.
