petsie
1
Which error do I make with the configuration, because I receive the following error message:
Error rendering data template: UndefinedError: 'dict object' has no attribute 'device_tracker'
How can I fix this?
- id: '1525596790130'
alias: 'Update notifications'
platform: state
entity_id: updater.updater
service: notify.telegram
data_template:
title: "Smarthome Update Info"
message: "Home Assistant {{ states.updater.updater.state }} is now available. {{now().strftime('%Y-%m-%d %I:%M %p')}}"
- id: '1525596790128'
alias: 'Mobile HomeIn'
platform: state
entity_id: device_tracker.env_handyreni, device_tracker.env_handypeter2, device_tracker.env_handytina
to: 'home'
data_template:
title: "Smarthome Info"
message: >
"{{ trigger.device_tracker.attributes.friendly_name }} ist zu Hause."
- id: '1525596790129'
alias: 'Mobile HomeOut'
platform: state
to: 'not_home'
data_template:
message: >
"{{ trigger.device_tracker.attributes.friendly_name }} verläßt das Haus."
petro
(Petro)
2
This is causing your problem.
your trigger is a state trigger. State triggers only have a few attributes.
Template variable |
Data |
trigger.platform |
Hardcoded: state |
trigger.entity_id |
Entity ID that we observe. |
trigger.from_state |
The previous state object of the entity. |
trigger.to_state |
The new state object that triggered trigger. |
trigger.for |
Timedelta object how long state has been to state, if any. |
message: >
{{ state_attr(trigger.entity_id, 'friendly_name') }} verläßt das Haus.
should work
EDIT: Fixed @lolouk44 typo
petsie
3
Thanks for the help, but if I apply this, then I get the following error.
Log Details (ERROR)
Thu May 10 2018 14:43:38 GMT+0200 (CEST)
Error rendering data template: UndefinedError: 'states_attr' is undefined
Modified configuration
platform: state
to: 'not_home'
data_template:
message: "{{ states_attr(trigger.entity_id, 'friendly_name') }} verläßt das Haus."
Home Assistant - Version 0.68.1
lolouk44
(lolouk44)
4
Typo, it’s state_attr
without the ‘s’
ooops, now it works perfectly. Many thanks for the help.
lolouk44
(lolouk44)
6
Credits go to @petro for the initial answer, I can’t accept them for just removing an ‘s’
