Having a error in my log and not sure where I can find where it is coming from
I have deleted a bunch of templates and nothing in my helpers to indicate dates that I can see. I understand it could be an integration causing it too
Not sure when I started seeing it unfortunately and I have been making lots of changes the last few months
I have tried a search in VSCode but It didn’t find anything
Source: helpers/template.py:2260
First occurred: December 15, 2023 at 9:21:53 AM (32600 occurrences)
Last logged: 8:25:06 AM
Template variable warning: 'dict object' has no attribute 'count' when rendering '{{ value_json.count }}'
Template variable warning: 'dict object' has no attribute 'scene_id' when rendering '{{ trigger.event.data.params.scene_id }}'
Those are templates in your configuration (not in an integration).
The first one references value_json which is used by many things but I suspect is part of some sensor’s configuration. The entity’s received payload is in JSON format and that template is extracting the value of the count key.
The second one references the trigger object so it could be in an automation or a Trigger-based Template Sensor (or similar Template entity). It appears to be referencing the result of an Event Trigger.
Thank you - i disabled some automations and part went away. Just dealing with the value_json and where it could be - been checking sensors - dont think i have anything hidden in a Lovelace card that could do it either.
Thanks for the start
You should be able to use VS Code to search for the strings in all files in all sub-directories of your config directory (including the hidden .storage directory). They’re there somewhere.
Looks like i got it - it was my home homepage that had widgets linking to HA - it was calling for a light count even thought i had removed that entity on the HA side.
Cleaner logs for now
