I’m running on a Docker session. I know some of the automation are still working, I can hear one of them being fired off in NodeRed to my google speaker.
CORE is at 2021.12.7(downgrade to .7 from 2021.12.8 to see if that would fix)
SUPERVISOR: 2021.12.2
Did a restart to the Dockers, and even the PC running it and still no go.
That will do it. I’m surprised that you were able to get in. I’m guessing duckdns? If you can still get in, look at the logs for the duck dns addon.
If you cant get back in IIRC you can force a cert update from the command line. Either that or if you can modify your config file and comment out the cert and key. Then restart and then use http to get in and correct what ever is wrong.
When I go to via the IP of the machine it works. … I deleted all that I could find for the duckdns references now I can connected(in the same browser that I couldn’t yesterday) and just says its not a secure connection, not a big deal for now I’m only accessing it from within my home. But I have to figure out how to get the Cert to update.
I left it be for a few hours, working from home got busy. Just checked and everything is back to working, no longer a non-secure connection . Guess it just needed sometime to resolve itself (update the certs)
