z2m have been working reliably for a few months and throughout dates. Today I updated whatever today’s update was.
It’s running in a VM in synology.
z2m now won’t start. Even after rebooting ha it is still like that
The logs:
[22:38:34] INFO: Preparing to start...
[22:38:34] INFO: Socat not enabled
[22:38:35] INFO: Starting Zigbee2MQTT...
Zigbee2MQTT:info 2023-02-16 22:38:38: Logging to console and directory: '/config/zigbee2mqtt/log/2023-02-16.22-38-38' filename: log.txt
Zigbee2MQTT:info 2023-02-16 22:38:38: Starting Zigbee2MQTT version 1.30.1 (commit #unknown)
Zigbee2MQTT:info 2023-02-16 22:38:38: Starting zigbee-herdsman (0.14.89)
Zigbee2MQTT:error 2023-02-16 22:38:39: Error while starting zigbee-herdsman
Zigbee2MQTT:error 2023-02-16 22:38:39: Failed to start zigbee
Zigbee2MQTT:error 2023-02-16 22:38:39: Check https://www.zigbee2mqtt.io/guide/installation/20_zigbee2mqtt-fails-to-start.html for possible solutions
Zigbee2MQTT:error 2023-02-16 22:38:39: Exiting...
Zigbee2MQTT:error 2023-02-16 22:38:39: Error: Error while opening serialport 'Error: Error: No such file or directory, cannot open /dev/ttyUSB0'
at SerialPort.<anonymous> (/app/node_modules/zigbee-herdsman/src/adapter/z-stack/znp/znp.ts:146:28)
at SerialPort._error (/app/node_modules/@serialport/stream/dist/index.js:76:22)
at /app/node_modules/@serialport/stream/dist/index.js:112:18
Looked in the VM, the sonoff usb is still in the settings
