This morning my HA VM that runs in a virtual box was not running. Digging through logs Looks like hassio was doing some sort of upgrade.
Does it look normal?
Dec 10 17:08:27 HomeAssistant hassio-supervisor[2794]: #033[32m19-12-10 23:08:2
7 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.G
etAll on /org/freedesktop/NetworkManager/DnsManager#033[0m
Dec 10 17:17:01 HomeAssistant CRON[29736]: (root) CMD ( cd / && run-parts --r
eport /etc/cron.hourly)
Dec 10 18:01:47 HomeAssistant hassio-supervisor[2794]: #033[32m19-12-11 00:01:4
7 INFO (MainThread) [hassio.updater] Fetch update data from https://version.hom
e-assistant.io/stable.json#033[0m
Dec 10 18:03:10 HomeAssistant systemd[1]: Started Run anacron jobs.
Dec 10 18:03:10 HomeAssistant anacron[31278]: Anacron 2.3 started on 2019-12-10
Dec 10 18:03:10 HomeAssistant anacron[31278]: Normal exit (0 jobs run)
Dec 10 18:13:01 HomeAssistant CRON[31642]: (root) CMD ( test -x /etc/cron.dai
ly/popularity-contest && /etc/cron.daily/popularity-contest --crond)
Dec 10 18:17:01 HomeAssistant CRON[31753]: (root) CMD ( cd / && run-parts --r
Dec 11 06:58:01 HomeAssistant systemd[1]: Starting Flush Journal to Persistent
Storage...
Dec 11 06:58:01 HomeAssistant systemd[1]: Activated swap /swapfile.
Dec 11 06:58:01 HomeAssistant systemd[1]: Reached target Swap.
Not sure if this helps since it shows the log since startup only, but here it is. It would have been from when I restarted the VM this morning. Is there a way to look at what the log looked like when it went down?
starting version 3.2.8
19-12-11 13:00:07 INFO (MainThread) [__main__] Initialize Hass.io setup
19-12-11 13:00:08 INFO (SyncWorker_0) [hassio.docker.supervisor] Attach to Supervisor homeassistant/amd64-hassio-supervisor with version 192
19-12-11 13:00:08 ERROR (MainThread) [hassio.supervisor] Supervisor does not run in Privileged mode. Hassio runs with limited functionality!
19-12-11 13:00:08 INFO (MainThread) [__main__] Setup HassIO
19-12-11 13:00:08 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.systemd1 - /org/freedesktop/systemd1
19-12-11 13:00:08 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.hostname1 - /org/freedesktop/hostname1
19-12-11 13:00:08 WARNING (MainThread) [hassio.dbus.rauc] Host has no rauc support. OTA updates have been disabled.
19-12-11 13:00:08 INFO (MainThread) [hassio.utils.gdbus] Connect to dbus: org.freedesktop.NetworkManager - /org/freedesktop/NetworkManager/DnsManager
19-12-11 13:00:08 INFO (MainThread) [hassio.host.info] Update local host information
19-12-11 13:00:08 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/hostname1
19-12-11 13:00:08 INFO (MainThread) [hassio.host.services] Update service information
19-12-11 13:00:08 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ListUnits on /org/freedesktop/systemd1
19-12-11 13:00:08 INFO (MainThread) [hassio.host.network] Update local network DNS information
19-12-11 13:00:08 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.DBus.Properties.GetAll on /org/freedesktop/NetworkManager/DnsManager
19-12-11 13:00:08 INFO (MainThread) [hassio.host.apparmor] Load AppArmor Profiles: {'hassio-supervisor'}
19-12-11 13:00:08 INFO (MainThread) [hassio.host.services] Reload local service hassio-apparmor.service
19-12-11 13:00:08 INFO (MainThread) [hassio.utils.gdbus] Call org.freedesktop.systemd1.Manager.ReloadOrRestartUnit on /org/freedesktop/systemd1
19-12-11 13:00:08 INFO (SyncWorker_2) [hassio.docker.interface] Attach to homeassistant/amd64-hassio-dns with version 1
19-12-11 13:00:08 INFO (MainThread) [hassio.dns] Update resolv from Supervisor
19-12-11 13:00:08 WARNING (MainThread) [hassio.dns] Can't write local resolv: [Errno 13] Permission denied: '/etc/resolv.conf'
19-12-11 13:00:08 INFO (MainThread) [hassio.dns] Start CoreDNS plugin
19-12-11 13:00:08 INFO (MainThread) [hassio.misc.forwarder] Start DNS port forwarding to 172.30.32.3
19-12-11 13:00:08 INFO (SyncWorker_4) [hassio.docker.interface] Clean hassio_dns application
19-12-11 13:00:15 INFO (SyncWorker_4) [hassio.docker.dns] Start DNS homeassistant/amd64-hassio-dns with version 1
19-12-11 13:00:15 INFO (SyncWorker_5) [hassio.docker.interface] Attach to homeassistant/qemux86-64-homeassistant with version 0.102.3
19-12-11 13:00:25 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/53caca22/snapcastserver/config.json: required key not provided @ data['arch']. Got None
19-12-11 13:00:25 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/53caca22/nextcloud/config.json: required key not provided @ data['arch']. Got None
19-12-11 13:00:25 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/53caca22/mopidy_alpine/config.json: required key not provided @ data['arch']. Got None
19-12-11 13:00:25 WARNING (MainThread) [hassio.store.data] Can't read /data/addons/git/53caca22/kanboard/config.json: required key not provided @ data['arch']. Got None
19-12-11 13:00:25 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/53caca22 repository
19-12-11 13:00:25 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/core repository
19-12-11 13:00:25 INFO (MainThread) [hassio.store.git] Load add-on /data/addons/git/a0d7b954 repository
19-12-11 13:00:25 INFO (MainThread) [hassio.store] Load add-ons from store: 78 all - 78 new - 0 remove
19-12-11 13:00:25 INFO (MainThread) [hassio.addons] Found 9 installed add-ons
19-12-11 13:00:25 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/amd64-addon-ssh with version 7.0
19-12-11 13:00:25 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/amd64-addon-samba with version 9.0
19-12-11 13:00:25 INFO (SyncWorker_0) [hassio.docker.interface] Attach to bestlibre/amd64-certbot with version 0.1.10
19-12-11 13:00:25 INFO (SyncWorker_7) [hassio.docker.interface] Attach to hassioaddons/terminal-amd64 with version v2.5.0
19-12-11 13:00:25 INFO (SyncWorker_4) [hassio.docker.interface] Attach to homeassistant/amd64-addon-duckdns with version 1.10
19-12-11 13:00:25 INFO (SyncWorker_0) [hassio.docker.interface] Attach to bestlibre/amd64-nginx-proxy with version 0.1.14
19-12-11 13:00:25 INFO (SyncWorker_1) [hassio.docker.interface] Attach to homeassistant/amd64-addon-mosquitto with version 5.1
19-12-11 13:00:25 INFO (SyncWorker_8) [hassio.docker.interface] Attach to hassioaddons/adb-amd64 with version 0.5.4
19-12-11 13:00:26 INFO (SyncWorker_6) [hassio.docker.interface] Attach to hassioaddons/appdaemon3-amd64 with version 4.1.0
19-12-11 13:00:26 INFO (MainThread) [hassio.updater] Fetch update data from https://version.home-assistant.io/stable.json
19-12-11 13:00:26 INFO (MainThread) [hassio.snapshots] Found 3 snapshot files
19-12-11 13:00:27 INFO (MainThread) [hassio.discovery] Load 1 messages
19-12-11 13:00:27 INFO (MainThread) [hassio.ingress] Load 0 ingress session
19-12-11 13:00:27 INFO (MainThread) [hassio.secrets] Load Home Assistant secrets: 29
19-12-11 13:00:27 INFO (MainThread) [__main__] Run Hass.io
19-12-11 13:00:27 INFO (MainThread) [hassio.api] Start API on 172.30.32.2
19-12-11 13:00:27 INFO (MainThread) [hassio.addons] Phase 'initialize' start 0 add-ons
19-12-11 13:00:27 INFO (MainThread) [hassio.addons] Phase 'system' start 3 add-ons
19-12-11 13:00:27 INFO (SyncWorker_2) [hassio.docker.interface] Clean addon_53caca22_nginx_proxy application
19-12-11 13:00:27 INFO (SyncWorker_8) [hassio.docker.interface] Clean addon_53caca22_certbot application
19-12-11 13:00:27 INFO (SyncWorker_9) [hassio.docker.interface] Clean addon_core_mosquitto application
19-12-11 13:00:32 INFO (SyncWorker_8) [hassio.docker.addon] Start Docker add-on bestlibre/amd64-certbot with version 0.1.10
19-12-11 13:00:34 INFO (SyncWorker_2) [hassio.docker.addon] Start Docker add-on bestlibre/amd64-nginx-proxy with version 0.1.14
19-12-11 13:00:35 INFO (SyncWorker_9) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-mosquitto with version 5.1
19-12-11 13:00:40 INFO (MainThread) [hassio.addons] Phase 'services' start 5 add-ons
19-12-11 13:00:40 WARNING (MainThread) [hassio.addons.validate] Unknown options name
19-12-11 13:00:41 WARNING (MainThread) [hassio.addons.validate] Unknown options guest
19-12-11 13:00:41 WARNING (MainThread) [hassio.addons.validate] Unknown options map
19-12-11 13:00:41 INFO (SyncWorker_5) [hassio.docker.interface] Clean addon_core_samba application
19-12-11 13:00:41 INFO (SyncWorker_8) [hassio.docker.interface] Clean addon_core_duckdns application
19-12-11 13:00:41 INFO (SyncWorker_9) [hassio.docker.interface] Clean addon_a0d7b954_terminal application
19-12-11 13:00:41 INFO (SyncWorker_6) [hassio.docker.interface] Clean addon_a0d7b954_adb application
19-12-11 13:00:41 INFO (SyncWorker_7) [hassio.docker.interface] Clean addon_core_ssh application
19-12-11 13:00:42 INFO (MainThread) [hassio.services.modules.mqtt] Set core_mosquitto as service provider for mqtt
19-12-11 13:00:54 INFO (SyncWorker_5) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-samba with version 9.0
19-12-11 13:01:02 INFO (SyncWorker_8) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-duckdns with version 1.10
19-12-11 13:01:04 INFO (SyncWorker_7) [hassio.docker.addon] Start Docker add-on homeassistant/amd64-addon-ssh with version 7.0
19-12-11 13:01:05 INFO (SyncWorker_9) [hassio.docker.addon] Start Docker add-on hassioaddons/terminal-amd64 with version v2.5.0
19-12-11 13:01:05 INFO (SyncWorker_6) [hassio.docker.addon] Start Docker add-on hassioaddons/adb-amd64 with version 0.5.4
19-12-11 13:01:11 INFO (SyncWorker_0) [hassio.docker.interface] Start homeassistant/qemux86-64-homeassistant
19-12-11 13:01:20 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_terminal.local.hass.io/info no role for a0d7b954_terminal
19-12-11 13:01:20 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_terminal.local.hass.io/info
19-12-11 13:01:21 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_terminal.local.hass.io/info no role for a0d7b954_terminal
19-12-11 13:01:21 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_terminal.local.hass.io/info
19-12-11 13:01:21 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_terminal
19-12-11 13:01:23 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_terminal.local.hass.io/info no role for a0d7b954_terminal
19-12-11 13:01:23 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_terminal.local.hass.io/info
19-12-11 13:01:23 INFO (MainThread) [hassio.api.security] /addons access from a0d7b954_terminal
19-12-11 13:01:24 INFO (MainThread) [hassio.api.security] /host/info access from a0d7b954_adb
19-12-11 13:01:26 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_terminal.local.hass.io/info no role for a0d7b954_terminal
19-12-11 13:01:26 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_terminal.local.hass.io/info
19-12-11 13:01:27 WARNING (MainThread) [hassio.api.security] /addons/a0d7b954_terminal.local.hass.io/info no role for a0d7b954_terminal
19-12-11 13:01:27 ERROR (MainThread) [hassio.api.security] Invalid token for access /addons/a0d7b954_terminal.local.hass.io/info
19-12-11 13:02:29 INFO (MainThread) [hassio.homeassistant] Detect a running Home Assistant instance
19-12-11 13:02:29 INFO (MainThread) [hassio.addons] Phase 'application' start 0 add-ons
19-12-11 13:02:29 INFO (MainThread) [hassio.tasks] All core tasks are scheduled
19-12-11 13:02:29 INFO (MainThread) [hassio.core] Hass.io is up and running
