My setup is a NAS running a VM of HAOS.
I went snooping around for the ip for HAOS, because the mobile apps stopped at the loading screen. I thought i’d try to connect the web-interface via the ip-adress…
This all is not my bread and butter, and went way over my head going into the terminal interface and mistakingly thought the command ‘ip’ would give the ip-address I was looking for.
From what I could deduce it then - instead….- went on a run, closing all sorts of things.
Indeed, when restarting the VM of HAOS it wasn’t a great succes. Last message was:
Cannot Connect to the Docker deamon at unix:///var/run/docker.sock. Is the docker deamon running?
[WARN] Home Assistant CLI not starting! Jump into emergency console…
#_
I have no clue what to do.
Anyone knows how to make things right again…….
